Handle the unit with care, do not knock or drop it. Do not store the
headphones below heavy items as the headphones may get deformed.
Although the headphones are resistant to sweat and rain, do not soak
them in water for a long time. When the surface of the product is dirty, wipe it clean with
a soft dry cloth. Pay special attention to the microphones, buttons, and charger pins.
Under normal circumstances, the headphones do not require servicing.
Use only original Suunto accessories. Damage caused by non-original
accessories is not covered by warranty.
Battery and charging
The battery performance on a single charge depends on how you use your headphones and in
what conditions. Low temperatures, for example, reduce the duration of a single charge.
In general, the capacity of rechargeable batteries decreases over time.
The headphones are fully charged in one hour, and you can listen to up to 10 hours of
music with one charge.
When the battery level is less than 5%, the headphones play a low battery alarm tone
every 5 minutes, and the red LED lights are blinking.
To check the battery status of your headphones, connect the product to Suunto app. You
can see the battery status on the headphones' page in the app.
For charging your headphones, you can use the supplied USB cable or the portable
powerbank.
USB cable
The USB charging cable is included in the product package. For charging the headphones
with the cable, connect the magnetic end of the cable to the charging port of the
headphones. If the headphones are switched on, they will automatically switch off when
the charging starts. While the headphones are charging, the LED lights are on. When the
battery is fully charged, the LED lights turn off.
Powerbank
For charging the headphones while on the move, the package of the product contains a
portable powerbank, offering extra 20 hours of battery life.
Before using the powerbank, you have to charge it with a USB-C cable. (The USB-C cable is
not included in the package.) To check the battery status of the powerbank, press the
button on the front side. Lights start blinking on the top of the device, each light
representing 25% of battery capacity.
To charge your Suunto
Wing with the powerbank, insert the headphones into the
holes on the top of it. If the headphones are switched on, they will automatically
switch off when connected to the powerbank. When the charging starts, the LED lights on
the headphones turn on and the lights on the powerbank are blinking for one minute. When
the battery is fully charged, the LED lights on the headphones turn off.
When inserting the headphones on the powerbank, make sure that the charging ports are
in contact. The charging starts only when you can see the lights of the headphones
on and the lights on the powerbank start blinking. If you do not see the lights,
move the headphones a bit so that the ports are in contact.
WARNING:
Before charging, ensure that the charging ports of the headphones and the powerbank
are free from any residual liquid. Liquid on the charging ports damage the
headphones' and the powerbank's circuit.
Please dispose of the device in accordance with local regulations for electronic waste. Do
not throw it in the garbage. If you wish, you may return the device to your nearest Suunto
dealer.
