1 / 5
SUUNTO A-30
NH USGS Compass - SUUNTO US
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS012100013
Suunto A-30
NH USGS Compass
$35
A compact, accurate compass for hiking and orienteering, also in poor visibility.
  • High grade steel needle with jewel bearing
  • Balanced for northern hemisphere, imperial scale
  • Luminescent markings for working in low light
  • Fixed declination correction scale
  • Baseplate with magnifying lens
  • Detachable snap-lock lanyard
    Choose Your Color
    Quantity
    $35
    Compare +
    30-Days Return
    Global Support
    SUUNTO A-30 NH USGS Compass
    $35
    Add to cart
    Designed in Finland
    Made in Finland
    Limited lifetime warranty
    Control marking holes
    Exceptionally stable & fast needle
    Luminescent markings for low light
    BASEPLATE COMPASS WITH MAGNIFYING LENS  FOR BACKPACKERS
    Stable operation
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    Specifications
    • Measurements
      57 x 114 x 10 mm / 2.24 x 4.49 x 0.39 "
    • Weight
      32 g / 1.13 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto A-30 NH USGS Compass, lanyard, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    • Liquid filled capsule for stable operation
    • Imperial scales
    • Control marking holes
    • Detachable snap-lock lanyard. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    • NSN: 6605-01-549-4770
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      inch, 1:24 000 mi, 1:50 000 mi
    • Declination correction
      fixed scale
    • Weight
      32 g / 1.13 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings and direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
    • 5 stars: 59 (77%)
    • 4 stars: 18 (23%)
    • 3 stars: 0 (0%)
    • 2 stars: 0 (0%)
    • 1 star: 0 (0%)
    S
    Sammy Thompson
    It very good
    It very good. Just what I was expecting
    F
    Frank Mejia
    I picked this compass because it could be trusted with in use
    I picked this compass because it could be trusted with in use. No other compass can prove it correctly. But I would recommend nice Suunto watch from your convenience company that would so excited purchase a New sunnto watch from you.
    B
    Brian Kliesen
    Great starter Scout compass
    Great starter compass. In this day and age of electronics, it is nice to find a simple and reliable compass. Right size, easy to use
    J
    J E
    North Arrow - North Hemisphere
    Suunto has great, reliable field compass. But, as Suunto delivers world wide, they have a product for both North and South hemisphere. Be sure to order the compass for where you plan to use the compass. If your compass points "South", rather than "North", it may be that there was a mistake in shipping or the order. I have seen some concern about the declination feature, but one just needs to know their local declination, and then make a manual east or west correction to get true north, rather that magnetic north bearing. The luminous dots and ring made for easy night use. The compass is liquid damped, and that makes for very good accuracy. With the limited lifetime warranty, this is an excellent buy.
    J
    J E
    D
    Derek Smith
    Very nice
    It's took me awhile before saying anything but this cupboard had held up. Through slot of woods it's done good very accurate.
    D
    Derek Smith
    Very nice
    M
    Marian
    Accurate and easy to carry
    My first compass and it is so easy to use. Really like it and light to have around your neck,
    M
    Marian
    A
    Adirondack Days
    Suunto top notch
    Excellent
    A
    Adirondack Days
    Suunto top notch
    Excellent
    B
    Barb G
    Suunto A-30 Compass
    Came quickly & exactly as described
    B
    Barb G
    Suunto A-30 Compass
    G
    Gary S.
    Suunto Compass
    The item was delivered on time and in good shape.The quality of the compass is what I expected from the manufacturer and the price I paid.I will be using it on the trails very soon, but testing went well.
    G
    Gary S.
    Suunto Compass
    I
    Ian H. Morgan
    Great product.
    Great product.
    I
    Ian H. Morgan
    Great product.
    Great product.
    d
    david
    One of the few compass brands to trust
    This is one of the brands that should be bought ,there are to many fakes out there that will get you lost. This compass is very hard to get false readings and I have tried keep away from watch and cell phones or any magnetic source and it will treat you well.
    d
    david
    S
    Stan Lukas
    Suuonto is an excellent product.
    Excellent for hiking.
    S
    Stan Lukas
    D
    DrMickeyMark
    My go-to compass
    Suunto has a reputation for quality and this compass does not disappoint, light weight, durable, scale markings and magnifier allow it to be used equally well on the map table and on the trail, very accurate, readings match electronic compass exactly, fluid stabilization keeps the needle steady on the move, dial turns easily and holds in place, the large numbers with glow in the dark make it easy to read night or day, this is my go-to compass
    D
    DrMickeyMark
    My go-to compass
    d
    daniel
    Top quality
    Good:WELL MADE - solid, needle settles almost immediately, glows well when 'charged,' small and light.Not so good:1. The DIAL #'s are small, I have to put on my reading glasses to set a course. This is not so easy dressed for below zero temperatures wearing a face mask, hat, headlamp and mittens.2. There is no adjustment for declination. Yes you can add or subtract the # and in my case thats a two step process (my brain). I could get used to that, but presetting the declination is best.
    d
    daniel
    Top quality
    w
    warren kiernan
    I love Amazon
    What a awesome service and everything was so easy to do and buy . Top product
    w
    warren kiernan
    I love Amazon
    M
    Maureen Barkley
    Compass Survival
    Love the sturdiness, size and warranty!
    M
    Maureen Barkley
    Compass Survival
    A
    Alex novoa
    good
    acurate
    A
    Alex novoa
    good
    acurate
    A
    Amazon Customer
    Suunto A-30 compass
    It seems well made. Suunto is a respected brand. I've only played with it so far, but this coming weekend I am going camping and hiking so I will try to put it to use. I'm pretty sure that I will be pleased with it.
    Recommended products
