Suunto Vertical 2
Pine Green
Ultimate adventure watch for outdoor expeditions and training — improved
- Bright 1.5'' AMOLED display
- Offline maps, improved navigation
- Up to 65 hours battery
- 115+ sport modes
- Integrated LED flashlight
- Improved heart rate tracking
Add your Suunto Vertical 2 to cart now to unlock a complimentary Suunto Lightweight Vest or Hoodie. Select your preferred style and size in the pop-up that appears.
Offer activates only when Vertical 2 is added to cart. One complimentary apparel item per qualifying order. Available styles, colors, and sizes are subject to stock availability. While supplies last.
Choose Your Color
Get FREE Worry-Free Delivery® by Seel with your Suunto sports watch purchase during our Black Friday event. Enjoy added protection against eligible package loss, damage in transit, and delivery delays.
Offer valid November 19, 2026, 7:00 AM – November 30, 2026, 11:59 PM PST. Excludes Suunto Ocean. Coverage is subject to Seel's terms and conditions. Does not cover accidental damage after delivery.
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 250 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
Specifications
Measurements49 x 49 x 13.6 mm / 1.93 x 1.93 x 0.54 "
Weight87 g / 3.07 oz
Bezel material:Stainless steel
Glass material:Sapphire crystal
Case material:Glass fibre reinforced polyamide
Strap material:Silicone
What's in the box?Suunto Vertical 2, charging cable, printed user documentation
Country of manufactureCN
Technical specifications
Wrist sizes:125-175 mm
Integrated wrist heart rate✔
Customizable watch faces✔
Touch screen lock✔
Touch display✔
Color display✔
Vibration alert✔
Automatic daylight saving time✔
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock✔
Dual time✔
Automatic timekeeping✔
Countdown timer✔
Stopwatch timer✔
LanguagesCS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*.
BacklightLTPO AMOLED
Configurable backlightautomatic brightness
Button lockduring exercise
Display size1,5''
Display typeMatrix
Display resolution466 x 466
Battery indicatorpercentage / icon
Metric and imperial units✔
Blood oxygen✔
Strap width:22 mm
Outdoor offline map storage32GB
Always-on display✔
CONNECTIVITY
Smartphone compatibilityMost common models supported
Connectivity (between devices)Bluetooth
Phone notifications on the watch✔
Music/Media controls on watch✔
Send predefined answers to incoming messages from watchAndroid only
Compatible with online sports communitiesStrava, TrainingPeaks and many more
Watch software updates from cloud✔
Compatible with Suunto app✔
Automatic over the air software updates✔
COMPASS
Digital compass✔
Tilt compensation✔
Direction scaledegrees / mils
Needlenorth indicator
Compass accuracy5°
Compass resolution1°
Declination correction✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +55° C / -5° F to +130° F
Storage temperature-20° C to +55° C / -5° F to +130° F
Recommended charging temperature0° C to +45° C / +32° F to +113° F
BATTERY LIFE
Intelligent charge reminders✔
Daily use: Smartwatch modeup to 20 days
Daily use: Standby time mode onlyup to 40 days
Training: All-Systems GNSS mode + Multi-Bandup to 65h (AOD 60h)
Training: All-Systems GNSS mode + Single-Bandup to 75h (AOD 70h)
Training: All battery modes battery promises65h / 75h / 110h / 250h
Training: Power saving GNSS modesup to 250h
DIVING FUNCTIONS
FREEDIVING
Depth meter for snorkeling10 m
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS, GALILEO, QZSS, BEIDOU
Simultaneous satellite systems4
Max connected satellites32
GPS recording rateBest, Good, OK, Low
Intelligent battery modesPerformance, Endurance, Ultra, Tour, Custom
Waypoint and visual route navigation✔
Zoom levels in navigation✔
Auto zoom based on route shape✔
Breadcrumb trail in real time✔
Outdoor terrain and satellite maps✔
Global heatmaps for 20 sports✔
Route planning with heatmaps✔
Personal route library synced to watch✔
Snap to route✔
Point of Interest (POI) navigation✔
ETA (estimated time of arrival)✔
GPS track analysis✔
Track logging, viewing and sharing✔
Offline maps on watch✔
GNSS frequency supportL1 + L5
Route planning with altitude profile✔
Offline map storage size32 GB
ETA (estimated time of arrival), remaining distance✔
ALTIMETER
Barometric altitude✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude in daily mode✔
Altitude acclimation with blood oxygen✔
Total ascent/descent✔
Vertical speed✔
Automatic alti/baro profile✔
Log recording rate1 s
Resolution1 m
Range-500 - 9999 m
WEATHER
Sunrise/sunset times✔
Storm alarm✔
Sea level pressure✔
Temperature✔
Temperature display range-20° C to +55° C / -5° F to +130° F
Temperature resolution1° C / 1.5° F
Pressure resolution1 hPa
Move altitude graph in Move summary✔
TRAINING FUNCTIONS
INTERVAL TRAINING
Interval guidance during training✔
Setup intervals✔
Structured intervals✔
HEART RATE
Heart rate measured from wrist✔
Heart rate belt compatibilityBluetooth HR belts
RR intervalwith Suunto Smart Sensor
Heart rate in beats per minute✔
Records heart rate in swimming✔
Heart rate graph in real time✔
Real-time average heart rate✔
Calories✔
Peak Training Effect✔
Recovery time✔
Personal heart rate zones✔
Lactate threshold detection✔
Fitness level (VO2max)✔
TRAINING LOAD
Logbook with exercise details✔
Exercise summary with lap details✔
Training load with totals by sport✔
Training logbook for long term overviews✔
TRAINING RECOVERY
Training based recovery time✔
Feeling stored after training to watch✔
SHARE AND RELIVE
Exercise rating and commenting✔
Exercise sharing to social media✔
Follow other members and get feedback via activity stream✔
SPEED AND DISTANCE
Cadence based speed and distance✔
GPS speed and distance✔
Chrono✔
Foot POD supportBluetooth Foot Pods
Autolaps✔
Manual laps✔
Analysis of pace, speed graphs and tracks on the map✔
24/7
ACTIVITY TRACKING
Step counter✔
Calories burned✔
Activity targetsSteps, Calories
Activity history✔
Calorie burn rate and heart rate during daily activities✔
Daily minimum heart rate tracking✔
SLEEP TRACKING
Sleep duration✔
Bed times✔
Sleep quality✔
Time awake✔
Average and minimum heart rate during sleep✔
Deep sleep✔
HRV from sleep✔
REM✔
Light sleep✔
STRESS AND RECOVERY
Daily resource level✔
Stress and recovery status✔
HRV measurement✔
SPORT EXPERTISE
MULTISPORTS
Multisport exercise summary on watch✔
Change sport mode during exercise✔
Preconfigured multisport modes✔
Post-analysis of multisport exercise by sport✔
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Snap to route✔
Running power✔
SuuntoPlus™ Ghost runner✔
Foot POD calibrationautomatic
Lap table in watch and Suunto app✔
Average, max, lap pace in real time✔
Interval guidance with running pace/heart rate/distance✔
CYCLING
Cycling speed✔
Average speed in real time✔
Bike POD with speed/cadence supportBluetooth Bike Pods
Bike power meter supportBluetooth Power meters
Bike Power (W), average and maximum (with power sensor)Bluetooth Power meters
Bike Lap and Lap Maximum Power (with power sensor)✔
Real-time lap table with avg HR, avg power and avg speed✔
Interval guidance with power/speed/heart rate✔
SWIMMING
Pool swim pace and distance✔
Openwater swim distance✔
Swimming time by pool length, lap, total✔
Swimming stroke rate, count and type✔
Stroke efficiency (SWOLF)✔
Automatic intervals✔
Interval lap table✔
SPORT MODES
Customizable sport modes and displays✔
Graph displays in sport modes✔
Pre-installed sport modes on watch> 90
SuuntoPlus™✔
