1 / 10
SUUNTO MC-2
G Mirror Compass - SUUNTO US
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
SUUNTO MC-2
1/10
Money-back guarantee
30-Days Return
Global Support
SKU: SS004252010
Suunto MC-2
G Mirror Compass
$92
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
  • Fast globally balanced needle with jewel bearing
  • Adjustable declination correction
  • Mirror for sighting bearings and signaling, with magnifying lens
  • Clinometer, metric UTM scales and inch ruler
  • Luminescent markings for working in low light
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    $92
    Compare +
    30-Days Return
    Global Support
    SUUNTO MC-2 G Mirror Compass
    $92
    Add to cart
    Designed in Finland
    Made in Finland
    Limited lifetime warranty
    Exceptionally stable & fast needle
    Baseplate with magnifying lens
    Luminescent markings for low light
    Sighting compass for mountain adventures
    Integrated clinometer
    The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    Stable operation
    Mirror for more
    The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
    Accurate bearings
    Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
    Specifications
    • Measurements
      65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
    • Weight
      75 g / 2.65 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto MC-2 G Mirror Compass, lanyard with wristlock and declination correction tool, quick release, Quick Guide
    • Country of manufacture
      FI
    • 20 degrees tilt margin for easier readings
    • Liquid filled capsule for stable operation
    • Sighting hole and notch for accurate bearings
    • Clinometer
    • Metric UTM scales and inch ruler
    • Baseplate with magnifying lens
    • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    • NSN: 6605-25-149-1938
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      cm, 1:25 000 km UTM, 1:50 000 km UTM
    • Imperial scales
      inch
    • Declination correction
      adjustable
    • Weight
      75 g / 2.65 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings, direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      degrees
    • Needle
      Suunto global needle
    • Globally balanced
    • Liquid filled and jewel bearing
    • Compass accuracy
      2°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Sighting
      mirror, notch and hole
    • Mirror
    • Magnifying lens
    CLINOMETER
    • Clinometer
    • Liquid filled
    • Clinometer scales
      0 ± 90°
    • Inlcination accuracy
      2°
    • Inclination resolution
      2°
    Recommended products
