Widgets
Widgets give you useful information of your activity and
training. The widgets are accessible from the watch face by
swiping up or turning the crown.
It is possible to pin a widget for quick and easy access. From
watch face, press the crown and double tap the screen to select
which widget you want to have pinned. It is also possible to pin
a widget under
Customize
in the
Control panel
The widgets can be turned on/off from the
Control panel
under
Customize
Widgets
. Select which widgets you want to use by turning the toggle on.
You can also select which widgets you want to use in your watch
and in which order by turning them on and off and sorting them
in Suunto app.
Weather
The weather widget provides you with information of the current
weather. It shows the current temperature, wind speed and
direction and current weather type both as text and icon.
Weather types can be, for example, sunny, cloudy, rainy etc.
Swipe up or turn the crown to see more detailed weather data
such as humidity, air quality and forecast data.
Make sure that your watch is connected with Suunto app to get
the most accurate weather data.
Notifications
If you have paired your watch with Suunto app, you can get
notifications of, for example, incoming calls and text messages,
on your watch.
When you pair your watch with the app, notifications are on by
default. You can turn them off from the settings under
Notifications
Messages received from some apps used for communication might
not be compatible with
Suunto Race 2
When a notification arrives, a pop-up appears on the watch face.
Press the crown to remove the popup. If the message doesn't fit
on the screen, turn the crown or swipe up to scroll through the
full text.
Below
Actions
, you can interact with the notification (the available options
vary depending on your phone and which of your mobile apps sent
the notification).
For apps used for communications, you can use your watch to send
a
Quick reply
. You can select and modify the predefined messages in Suunto
app.
Notification history
If you have unread notifications or missed calls on your mobile
device, you can view them on your watch.
From the watch face, swipe up and select the notification widget
and then turn the crown to scroll through the notification
history.
The notification history is cleared when you check the messages
on your mobile device or if you select
Clear all messages
in the notification widget.
Media controls
Your
Suunto Race 2
can be used to control the music, podcast, and other media
played on your phone or being cast from your phone to another
device.
You need to pair your watch with your phone before you can use
Media controls.
To access the media controls widget, swipe up from watch face
or, during an exercise, press the crown until the media control
widget is shown.
In the media control widget, tap play, next track or previous
track to control your media.
Swipe up or turn the crown to enter the complete setup of the
media controls.
Press the lower button to exit the media control widget.
Heart rate
The HR widget provides a quick snapshot of your heart rate and a
12-hour graph of your heart rate. The graph is plotted using
your average heart rate based on 24-minute time slots.
Your minimum heart rate from the last 12 hours is a good
indicator of your recovery state. If it is higher than normal,
you probably are not yet fully recovered from your last training
session.
If you record an exercise, the daily HR values reflect the
elevated heart rate and calorie consumption from your training.
But keep in mind that the graph and consumption rates are
averages. If your heart rate peaks at 200 bpm while exercising,
the graph does not show that maximum value, but rather the
average from the 24 minutes during which you hit that peak rate.
To be able to see the daily HR widget values, the daily HR
feature needs to be activated. You can toggle the feature on or
Activity
or scroll down to the end of the HR widget and activate it
there.
With this feature on, your watch activates the optical heart
rate sensor on a regular basis to check your heart rate. This
slightly increases battery power consumption.
Once activated, your watch needs 24 minutes before it can start
display heart rate information.
Swipe right or press the lower button to return to the watch
face view.
Recovery, HRV (Heart Rate Variability)
Heart Rate Variability (HRV) is a measure of the variation in
time between heartbeats and its value is a good predictor of
overall health and well-being.
HRV helps you to understand your recovery state and it measures
your physical and mental stress and implies how ready your body
is to train.
To be able to get an effective average HRV, you need to track
your sleep at least three times a week over a longer period to
establish your HRV range.
Different situations and conditions such as a relaxed holiday,
physical and mental exertion or developing flu can lead to
changes in HRV.
Please refer to
www.suunto.com
or Suunto app to learn more about HRV recovery.
Progress
The progress widget provides you with data that helps you to
increase your training load over a longer period of time,
whether it is the training frequency, duration or intensity.
Every training session gets a Training Stress Score (TSS) (based
on the duration and the intensity) and this value is the base
for calculating the training load for both short and long-time
averages. From this TSS value, your watch can calculate your
fitness level (defined as VO₂max), CTL (Chronic Training Load)
and also provide you with an estimation on your lactate
threshold and a prediction on your running pace on various
distances.
The ramp rate is a metric that monitors your rate of increase or
decrease in your fitness over a set time.
Your aerobic fitness level is defined as VO₂max (maximal oxygen
consumption), a widely recognized measure of aerobic endurance
capacity. In other words, VO₂max shows how well your body can
use oxygen. The higher your VO₂max, the better you can use
oxygen.
The estimation of your fitness level is based on detecting your
heart rate response during each recorded running or walking
workout. To get your fitness level estimated, record a run or
walk with a duration for at least 15 minutes while wearing your
Suunto Race 2
The widget also views your estimated fitness age. Fitness age is
a metric value that reinterprets your VO₂max value in terms of
age.
Improvement of VO₂max is highly individual and it depends on
factors such as age, gender, genetics and training background.
If you are already very fit, increasing your fitness level
will be slower. If you are just starting to exercise
regularly, you may see a quick increase in fitness.
Please refer to
www.suunto.com
or Suunto app to learn more about Suunto's training load
analysis concept.
Training
The training widget provides you with information on the
training load for the current week and also the total duration
on all of your training sessions.
This widget also gives you guidance on how your form is, if you
start losing fitness, if you are maintaining it or if you
currently do productive training.
The CTL (Chronic Training load) value is a weighted average on
your long term TSS (Training Stress Score), the more you train
the higher your fitness is.
The ATL (Acute Training Load) value is the 7-day weighted
average of your TSS and basically tracks how fatigued you
currently are.
The TSB (Training Stress Balance) value shows your form which is
basically the difference between long-term, chronic training
load (CTL) and short-term, acute training load (ATL).
Please refer to
www.suunto.com
analysis concept.
Recovery, training
The recovery training widget shows your current form and your
workout feelings the last week as well as your last 6 weeks.
Please note that you need to register you feeling after each
workout to get this data, see
Feeling
This widget will also tell you how your recovery matches your
current training load.
Please refer to
www.suunto.com
analysis concept.
Blood oxygen
WARNING:
Suunto Race 2
is not a medical device and the blood oxygen level indicated
by
Suunto Race 2
is not intended for diagnosing or monitoring medical
conditions.
You can measure your blood oxygen level with
Suunto Race 2
. From the watch face view, swipe up or turn the crown to scroll
to and select the Blood oxygen widget.
Blood oxygen level can provide an indication of overtraining or
fatigue and the measurement can also be a helpful indicator of
high altitude acclimation progress.
Normal blood oxygen levels are between 96% and 99% at sea level.
At high altitudes, healthy values can be slightly lower.
Successful acclimation to high altitude makes the value increase
again.
How to measure your blood oxygen level from the Blood oxygen
widget:
Select
Measure now
- Hold your hand still while the watch is measuring.
If the measuring failed, please follow the in-watch
instructions.
When the measuring is complete, your blood oxygen value is
displayed.
You can also measure your blood oxygen level during your
Sleep
Sleep
A good night's sleep is important for a healthy mind and body.
You can use your watch to track your sleep and follow how much
sleep you get on average.
When you wear your watch while sleeping,
Suunto Race 2
tracks your sleep based on accelerometer data.
To track sleep:
From watch face, scroll down and select
Sleep
Toggle on
Sleep tracking
You can choose to have your watch in Do Not Disturb mode during
your sleeping hours and also choose if you want to measure your
Blood oxygen and HRV tracking during your sleep.
Once you have enabled sleep tracking, you can also set your
sleep target. A typical adult needs between 7 and 9 hours of
sleep per day, though your ideal amount of sleep may vary from
the norms.
Sleep trends
When you wake up, you are greeted with a summary of your sleep.
The summary includes, for example, the total duration of your
sleep, as well as the estimated time you were awake (moving
around) and the time you were in deep sleep (no movement).
In addition to the sleep summary, you can follow your overall
sleep trend with the sleep widget. From the watch face, swipe up
or turn the crown until you see the
Sleep
widget. The first view shows your last sleep and a graph of the
last seven days.
While in the sleep widget, you can swipe up to see the sleep
details for your last sleep.
All sleep measurements are based on movement only, so they are
estimates that may not reflect your actual sleep habits.
Measuring heart rate, blood oxygen and heart rate variability
(HRV) while sleeping
If you wear your watch during the night, you can get additional
feedback on your heart rate, HRV and blood oxygen level while
sleeping.
Automatic Do Not Disturb mode
You can use the auto Do Not Disturb setting to automatically
enable Do Not Disturb mode while you sleep.
Steps and calories
Your watch keeps track of your overall activity level throughout
the day. This is an important factor whether you just aim to be
fit and healthy or you are training for an upcoming competition.
It is good to be active, but when training hard, you need to
have proper rest days with low activity.
The activity counter automatically resets at midnight every day.
At the end of the week (Sunday), the watch provides a summary of
your activity showing your average for the week and daily
totals.
Your watch counts steps using an accelerometer. The total step
count accumulates 24/7, also while recording training sessions
and other activities. However, with some specific sports, such
as swimming and cycling, steps are not counted.
The top value in the widget shows the total step count for that
day and the bottom value is the estimated amount of active
calories you have burned so far during the day. Below this you
see the total calories burned. The total includes both active
calories and your Basal Metabolic Rate, BMR (see below).
The half rings in the widget indicate how close you are to your
daily activity goals. These targets can be adjusted to your
personal preferences (see below).
You can also check your steps and calories burned over the last
seven days by swiping up from the widget.
Activity goals
You can adjust your daily goals for both steps and calories.
From the settings, select
Activity
to open the activity goal settings.
When setting your steps goal, you define the total number of
steps for the day.
The total calories you burn per day is based on two factors:
your Basal Metabolic Rate (BMR) and your physical activity.
Your BMR is the amount of calories your body burns while at
rest. These are the calories your body needs to stay warm and
perform basic function like blink your eyes or beat your heart.
This number is based on your personal profile, including factors
such as age and gender.
When you set a calorie goal, you define how many calories you
want to burn in addition to your BMR. These are your so-called
active calories. The ring around the activity display advances
according to how many active calories you burn during the day
compared to your goal.
Sun & Moon
From watch face, swipe up or turn the crown to scroll to the Sun
& moon widget. Your watch will give you the time until the
next sunset or sunrise, depending on which one comes next.
If you select the widget, you get more details such as the time
when the sun rises and sets, and also the current moon phase.
Resources
Your resources are a good indication of your body's energy
levels, which directly influence your capacity to handle stress
and cope with the daily challenges.
Stress and physical activity deplete your resources, while rest
and recovery restore them. Good sleep is an essential part of
ensuring your body has the resources it needs.
When your resource levels are high, you will likely feel fresh
and energetic. Going for a run when your resources are high
means you'll probably have a great run, because your body has
the energy it needs to adapt and improve as a result.
Being able to track your resources can help you manage and use
them wisely. You can also use your resource levels as a guide to
identify stress factors, personally effective recovery boosting
strategies, and the impact of good nutrition.
Stress and recovery uses optical heart sensor readings and to
get those during the day, daily HR must be enabled, see
Heart rate
It is important that your Max HR and Rest HR are set to match
your heart rate to ensure that you get the most accurate
readings. By default, the Rest HR is set to 60 bpm and the Max
HR is based on your age.
These HR values can easily be changed in the settings under
General
Personal
Use the lowest heart rate reading measured during your sleep
as your Rest HR.
From the watch face, turn the crown or swipe up to scroll to the
resources widget.
The color around the widget icon indicates your overall resource
level. If it is green, it means you are recovering. The status
tells you your current state (active, inactive, recovering or
stressed). The bar chart shows your resources over the last 16
hours and the percentage value is an estimate of your current
resource level.
Alti & Baro
Suunto Race 2
constantly measures absolute air pressure using the built-in
pressure sensor. Based on this measurement and your altitude
reference value, it calculates altitude or air pressure.
CAUTION:
Keep the area around the two air pressure sensor holes located
at six o'clock on the side of your watch free of dirt and
sand. Never insert any objects into the holes as this may
damage the sensor.
alti & baro widget. The widget has three views that can be
accessed by swiping up and down. The first view displays the
current altitude.
Swipe up to see the barometric pressure and the barometer trend
graph.
Swipe up again to see the temperature.
Swipe down or press the lower button to go back.
Be sure to have your altitude reference value set correctly (see
Altimeter
). The altitude of your current location can be found from most
topographic maps or major on-line map services such as Google
Maps.
Changes in local weather conditions affect altitude readings. If
local weather changes often, you should reset the altitude
reference value regularly, preferably before starting your next
journey.
Automatic alti-baro profile
Weather and altitude changes both cause a change in air
pressure. To handle this,
Suunto Race 2
automatically switches between interpreting changes in air
pressure as altitude or weather changes based on your movement.
If your watch senses vertical movement, it switches to measuring
altitude. When you are viewing the altitude graph, it is updated
with a maximum delay of 10 seconds.
If you are at a constant altitude (less than 5 meters of
vertical movement within 12 minutes), your watch interprets air
pressure changes as weather changes and adjusts the barometer
graph accordingly.
Compass
Suunto Race 2
has a gyro-assisted compass that allows you to orient yourself
in relation to magnetic north. The tilt-compensated compass
gives you accurate readings even if the compass is not
horizontally level.
You can access the compass by swiping up from the watch face or
by turning the crown and selecting
Compass
The compass widget includes the following information:
- Arrow pointing to magnetic north
- Heading cardinal
- Heading in degrees
- Altitude
- Barometric pressure
To exit the compass widget, press the lower button.
While you are in the compass widget, you can swipe up from the
bottom of the screen to open a list of shortcuts. The shortcuts
give you quick access to navigation actions such as checking the
coordinates of your current location or selecting a route to
navigate.
Calibrating compass
If the compass is not calibrated, you are prompted to calibrate
the compass when you enter the compass widget.
The compass calibrates itself when in use, but if the watch
has been affected by strong magnetic fields or a hard knock,
the compass might show the wrong direction. Do a new
calibration to resolve this issue.
Setting declination
To ensure correct compass readings, set an accurate declination
value.
Paper maps point to true north. Compasses, however, point to
magnetic north – a region above the Earth where the Earth’s
magnetic fields pull. Because magnetic North and true North are
not at the same location, you must set the declination on your
compass. The angle in between magnetic and true north is your
declination.
The declination value appears on most maps. The location of
magnetic north changes yearly, so the most accurate and
up-to-date declination value can be found from websites such as
www.magnetic-declination.com
Orienteering maps, however, are drawn in relation to magnetic
north. If you are using an orienteering map, you need to turn
the declination correction off by setting the declination value
to 0 degrees.
You can set your declination value from the
Settings
under
Navigation
Declination
Timer
Your watch includes a stopwatch and countdown timer for basic
time measurement. From the watch face, swipe up or turn the
crown until you reach the timer widget.
When you first enter the widget, it shows the stopwatch. After
that, it remembers whatever you used last, stopwatch or
countdown timer.
Swipe up to open the
Set timer
shortcuts menu where you can change the timer settings.
Stopwatch
Start and stop the stopwatch by pressing the upper button. You
can resume by pressing the upper button again. Reset by pressing
the lower button.
Exit the timer by pressing the lower button.
Countdown timer
In the timer widget, swipe up to open the shortcuts menu. From
there you can select a pre-defined countdown time or create
custom countdown time.
Stop and reset as needed with the upper and lower buttons.
Exit the countdown timer by pressing the lower button.
