1 / 4
SUUNTO TANK POD - SUUNTO US
1/4
Money-back guarantee
30-Days Return
Global Support
SKU: SS020306000
Suunto Tank POD
$439
Wireless tank pressure transmitter for Suunto Nautic, Suunto Nautic S, Suunto Ocean, Suunto D5, Suunto EON Steel, EON Steel Black and EON Core.
  • High quality
  • Easy pairing
  • Cleaned for oxygen service
  • Set your own gas alerts
  • Accurate pressure reading
Choose Your Color
Quantity
$439
Compare +
30-Days Return
Global Support
SUUNTO TANK POD
$439
Add to cart
Suunto Tank POD
The Suunto Tank POD is a wireless tank pressure transmitter that allows you to view current tank pressure with just a glance at your wrist. The Suunto Tank POD is cleaned for oxygen service for added safety when diving with enriched air.
The pairing procedure is very intuitive; just pressurize the system, hold your Suunto Nautic, Suunto Nautic S, Suunto Ocean, Suunto D5, Suunto EON Steel, Suunto EON Steel Black or Suunto EON Core close to the Tank POD and after a few seconds a menu pops up on the screen showing the serial number, battery status and the tank pressure.
Product highlights
  • Easy pairing
BENEFITS
Easily read key dive details on your wrist
Enjoy increased comfort and safety during the dive and use your Suunto Ocean, Suunto D5, Suunto EON Core, Suunto EON Steel or Suunto EON Steel Black together with Suunto Tank POD.
Paired with Suunto Tank POD, simply check the dive computer on your wrist for
  • accurate gas pressure reading
  • remaining gas time
  • clear color-coding indicating gas level
  • low in gas warning, so you will have enough time for a safe ascend
  • setting your own gas alarms
The pairing procedure is very intuitive; just pressurize the system and hold your Suunto D5, Suunto EON Steel, Suunto EON Steel Black or Suunto EON Core close to the Tank POD.
High quality and tested tough
Suunto Tank POD has a safe and robust construction according to the most stringent European safety standards and the built-in Suunto quality. The Suunto Tank POD comes cleaned for oxygen service to provide that extra added safety when diving with higher oxygen concentrated gases like Nitrox. With the built-in gas alarms Suunto Tank POD along with your Suunto dive computer will never let you down.
Follow your development as a diver
After diving, transfer your dive logs easily over Bluetooth to your mobile. In Suunto app you can analyze your gas consumption and follow how it develops the more dive experience you gain.
With Suunto app on your mobile, share your underwater adventures with friends and be the first to know of software updates bringing new features to your dive computer.
  • 5 stars: 7 (100%)
  • 4 stars: 0 (0%)
  • 3 stars: 0 (0%)
  • 2 stars: 0 (0%)
  • 1 star: 0 (0%)
P
Peter Fallat
Easy to setup
Easy to setup. Works great with no issues
A
Adam Larkin
Great customer service
I haven't gotten a chance to dive with my new dive computer or this pod, but I can tell you without a doubt. The customer service and the speed in which this arrived was amazing. I wasn't able to buy the nautic. S from you, because you're out of stock of it, but I was able to buy it through another online dive catalog and bundling it with the savings that you gave me on this pod. Saved me $ 20 over ordering it any other way. Due to a mess up with Amazon, I received the wrong dive computer 3 times in fact, it wasn't even your dive computer. It was the race 2 so I was at the end of my rope, and I needed to make sure that I got the right dive computer. And the pod, and you were amazing in getting me had very least a pod, but I am very grateful for. I will update my review as I dive. But i'm sure it'll stay the same.
R
Rick Larsen
A great addition to your Suunto dive computer
A great addition to your Suunto dive computer. Works great and makes it easy to keep an eye on all of your diet data right on your wrist.
A
Anonymous
Upgraded Tank Pods (and Computer)
I have used Suunto Tank Pods for a number of years with the older version paired to a Suunto Vyper computer. That model was more fragile in its connection and I have found this Pod to be vastly more robust in connecting consistently with my computer (Suunto Nautic). I have already completed quite a few dives both on air and nitrox as well as using the duel pod mode with my sidemount setup and two Tank Pods. So far very happy with the performance all round.
J
Jose l hernandez (MCY-427320) Hernandez
Una herramienta muy útil y precisa
Una herramienta muy útil y precisa, especialmente para los buzos tecnicos
G
Greg Milburn
Ocean, Eon Core, and Tank Pods work great
The Suunto tank pod paired with the Suunto Ocean watch is a great setup for scuba diving. Easy to link and make adjustments based on different tank sizes or Nitrox mixes. My partner uses the Suunto Eon Core with tank that works great too. We highly recommend.
T
Todd
I highly recommend the Tank Pod especially paired with the Ocean.
I recently began using the tank pod and have paired it with my Suunto Ocean. Thus far, it has worked great. I am an instructor and have used it during a couple of closed water sessions and a couple of open water sessions. I appreciate the additional data provided over my old hose-based dive computer. I had heard reports of divers using other brands being able to hear clicking sounds coming from their Bluetooth tank pods, but I have not heard anything from this one. I highly recommend both the tank pod and Suunto Ocean.
