1 / 2
Suunto M-3 G Compass - SUUNTO US
1/2
Money-back guarantee
30-Days Return
Global Support
SKU: SS021370000
Suunto M-3
G Compass
$72
A baseplate global compass for convenient direction taking even in demanding conditions.
  • Fast, globally balanced needle with jewel bearing
  • Metric and Imperial UTM scales
  • Adjustable declination correction
  • Baseplate with magnifying lens
  • Clinometer combined
  • Operable in low light with luminescent markings
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    $72
    Compare +
    30-Days Return
    Global Support
    $72
    Add to cart
    THE BASEPLATE COMPASS FOR GLOBETROTTERS
    The adventure compass. A reliable compass is essential for navigating and surviving in extreme conditions. These hardy baseplate compasses are ready for the challenge.
    PRODUCT HIGHLIGHTS
    Specifications
    • Measurements
      120 x 61 x 14 mm / 4.72 x 2.4 x 0.55 "
    • Weight
      48 g / 1.69 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto M-3 G Compass, lanyard, quick release, Quick Guide
    • Country of manufacture
      FI
    • Fast globally balanced needle with jewel bearing
    • 20 degrees tilt margin for easier readings
    • Liquid filled capsule for stable operation
    • Clinometer
    • Luminescent markings for working in low light
    • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    • NSN: 6695-58-000-9441
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      cm, 1:25 000 km UTM, 1:50 000 km UTM
    • Imperial scales
      inch, 1:24 000 mi, 1:24 000 km UTM, 1:50 000 km UTM
    • Declination correction
      adjustable
    • Weight
      48 g / 1.69 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings and direction of travel
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      degrees
    • Needle
      Suunto global needle
    • Globally balanced
    • Liquid filled and jewel bearing
    • Compass accuracy
      2°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
    CLINOMETER
    • Clinometer
    • Liquid filled
    • Clinometer scales
      0 ± 90°
    • Inlcination accuracy
      2°
    • Inclination resolution
      2°
