Out of Stock
SUUNTO M-3
NH COMPASS - SUUNTO US
Money-back guarantee
30-Days Return
Global Support
SKU: SS021369000
Suunto M-3
NH Compass
$59
A premium quality precision compass for convenient direction taking even in demanding conditions.
  • Fast, globally balanced needle with jewel bearing
  • Balanced for northern hemisphere
  • Adjustable declination correction
  • Baseplate with magnifying lens
  • Metric and Imperial scales
  • Operable in low light with luminescent markings
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    $59
    Out of Stock
    Compare +
    30-Days Return
    Global Support
    SUUNTO M-3 NH COMPASS
    $59
    Out of Stock
    THE BASEPLATE COMPASS FOR ADVENTURERS
    The adventure compass. A reliable compass is essential for navigating and surviving in extreme conditions. These hardy baseplate compasses are ready for the challenge.
    PRODUCT HIGHLIGHTS
    • Adjustable Declination correction
    • Magnifying lense on transparent baseplate for easy use with map
    Specifications
    • Measurements
      61 x 120 x 14 mm / 2.4 x 4.72 x 0.55 "
    • Weight
      46 g / 1.62 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto M-3 NH Compass, lanyard, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    • High grade steel needle with jewel bearing
    • Liquid filled capsule for stable operation
    • Luminescent markings for working in low light
    • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      cm, 1:20 000 km, 1:25 000 km, 1:50 000 km
    • Imperial scales
      inch, 1:24 000 mi, 1:50 000 mi
    • Declination correction
      adjustable
    • Weight
      46 g / 1.62 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings and direction of travel
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
