SUUNTO MCB
NH MIRROR COMPASS - SUUNTO US
Money-back guarantee
30-Days Return
Global Support
SKU: SS012277013
Suunto MCB
NH Mirror Compass
$40
A floating, ergonomic multi-purpose mirror compass that combines precision with practicality.
  • High grade steel needle with jewel bearing
  • Mirror for sighting bearings and signaling
  • Balanced for northern hemisphere
  • Fixed declination correction scale
  • Detachable snap-lock lanyard with whistle
    Quantity
    $40
    Compare +
    30-Days Return
    Global Support
    SUUNTO MCB NH MIRROR COMPASS
    $40
    Add to cart
    THE SAFETY COMPASS
    The trekking compass. These simple sighting compasses add useful features that will help trekkers go even further into the great outdoors.
    PRODUCT HIGHLIGHTS
    • Mirror for accurate direction taking and signaling
    • Compact
    Specifications
    • Measurements
      56 x 68 x 18 mm / 2.2 x 2.68 x 0.71 "
    • Weight
      36 g / 1.27 oz
    • What's in the box?
      Suunto MCB NH Mirror Compass, lanyard, Whistle, Quick Guide
    • Country of manufacture
      FI
    • Sighting hole and notch for accurate bearings
    • Liquid filled capsule for stable operation
    • Floating
    • Suunto limited lifetime warranty
    • Made in Finland
    Technical specifications
    • Metric scales
      cm
    • Imperial scales
      inch
    • Declination correction
      fixed scale
    • Weight
      36 g / 1.27 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Floating construction
    • Lanyard quick release
    • Attachment
      lanyard
    • Whistle
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Sighting
      mirror, notch and hole
    • Mirror
    • 5 stars: 22 (55%)
    • 4 stars: 18 (45%)
    • 3 stars: 0 (0%)
    • 2 stars: 0 (0%)
    • 1 star: 0 (0%)
    a
    aaron
    For price I was shocked one was a couple degrees off.
    I bought 2 kb-20's and 2 kb-14's to decide on accuracy and fondness. One kb-20 was a couple degrees off. I settled on a higher price kb14. The 14's disc seems to glide smoother, and appears to handle a little better angling up or down, a tiny bit; and comes with a simple soft belt Velcro pouch and separate lanyard string. The kb-20 comes with an integrated black neck string. It also has mid-degree marks if that's what you want (on kb-14). Here's a picture through the kb-20 peephole because I didn't see anyone else have a clear one. You might be able to find better prices elsewhere, but maybe shipping cost would end up being the same.
    A
    Anonymous
    Very nice delivered
    Very nice delivered quickly
    A
    Arty Farty
    Perfect compass to teach children land navigation
    Perfect compass to teach children land navigation.
    E
    Eric Walter
    excellent compass
    excellent compass. perfect for my needs better thank military issue
    A
    Amazon Customer
    ... find the corners of my land and it worked great. It was simple to use and it shipped ...
    I used it to find the corners of my land and it worked great. It was simple to use and it shipped faster than they said. This is a very good compass.
    P
    Pierce Greer
    Four Stars
    Great by when I got the product the lanyard was broken
    A
    Archaeology Chick
    Good compass
    Love this compass for archaeology surveys & fieldwork. It��s accurate & convenient.
    A
    Amazon Customer
    Worth the money.
    High quality, good accuracy. Using this to align antenna azmiuths. I wish suunto would make a affordable digital version of this tool that could connect to a gps satelite, as the steel on towers can throw this tool off.
    r
    rktman
    Great compass
    Use for survey retracement.Wish it had declination adjustment, but not a real problem.
    C
    Coach
    No news is good news
    Purchased for emergency/disaster preparedness, hopefully won't have to use it. Nothing to report so far. Lightweight, seems like it will be easy to use.
    S
    Sue D.
    Four Stars
    Will serve the purpose it was intended for
    D
    Dave
    I haven't put it to the test yet but it doesn't look like it's going to be as durable as I expected
    Works as expected. I haven't put it to the test yet but it doesn't look like it's going to be as durable as I expected.
    R
    Richard Tan
    Used it to find location
    I like this product and it serves my need. It is easy to use
    T
    Timothy P.
    Great brand, great price
    Haven't field tested yet, but it does what it's supposed to so far. Great for an edc bag without being too tactical. Probably going to buy another
    J
    James
    most reliable compass out there
    I've had one of these for about a decade now. I use it regularly and its never gotten a bubble. Wonderful value.
    K
    Kim
    Accurate but hold level
    A forester for 40 years. Used this compass, never liked the Silva mirror compasses, used to run land lines, cruise timber and keep from getting lost, very accurate and lots lighter than thelet metal version.
    E
    Ellen
    Fortunately, there was no immediate need for the compass ...
    This product does just what it advertised and is just what my husband was looking for. The delivery was much, much slower than promised. Fortunately, there was no immediate need for the compass to arrived on time.
    R
    Romar
    really cheap feel and light
    This plastic compass looks and feels like it should sell for $3 instead of $30. The hinge is just a bendable plastic, probably would break over time. It does seem stable, however, and for that reason alone, I gave the compass a four star rating.
    M
    Michael C
    Accurate
    Accurate compass
    B
    Brandon M.
    Emergency fallback
    Better than nothing I suppose. A pair of decent marine binoculars with internal compass is on my agenda, until then I'll make do with this.
    L
    LowKey
    Functions perfectly, but a bit delicate
    I love this compass, and would have given it 5 stars if not for being afraid of it breaking. It is very light weight, though, and the whistle is a nice touch. I own 2 other compasses, and this is the one I will be using from now on. I'll just have to be very careful with it.
    M
    Mark Vallone
    Throw the whistle away.
    It's a fully functioning compass with some nice features, but it's light weight to the point of feeling flimsy.The compass needle is free floating, not oil filled and I'm not sure how durable the "hinge' will turn out to be.I get that it's not made in China, but I think it's kind of expensive for what it is.
    A
    Amazon Customer
    Great compass
    Well made and works great!
    D
    Dylan Smith
    Great sighting compass.
    This is my second suunto of this type after losing my old one. As a field archaeologist this does the job for keeping on your transect in the field. It works just as well as the more expensive version with the aluminum case.
    R
    Robert Lewter
    Really accurate
    For the money, or for more money, you can't beat this one. It's accurate, light, and it floats. It's basic, but easy to use. I have a compass collection and this is going to be one that I use constantly.
    j
    james w. reed jr
    SS012277013 SUUNTO MCB NH Mirror Compass
    this is a nice compact compass with every thing one really needs for orientation light weight easy to readand the whistle is an add bonus
    A
    Aaron LaGere
    Light, fragile, but effective.
    The clear trade-off here is how flimsy the plastic feels so try not to drop it on any rocks or slam it in your pack. It works perfectly and will save a couple of ounces on it's heavier metal counterparts built for durability.
    R
    Red Scoutmaster
    one of the best compasses
    J
    Jon
    Foggy mirror, otherwise ok.
    I'm giving this item 4 stars because the mirror is so foggy that it is useless. I can still use the compass but I prefer my gear to be multifunctional and I wanted a signal mirror and self aid mirror. I guess I'll have to keep looking for that.At least it does point north.
    K
    Kindle Customer
    Great tool!
    I was really glad I ordered a new compass! I thought I lost the one I had, but now I have two just in case! I love the ease of use and I can see the numbers,!
    Y
    Youser
    Affordable and accurate
    Works well and is compact. Plastic seems a little lightweight but hopefully it will be durable. I like it and it��s a backup compass for me. If I was a daily user I would pay more for a better model. This fits the bill perfectly for an emergency backup though.
    t
    terrance h.
    Nice but too small.
    Also too plasticky.Needle is ok, but only work within small range of tilt angles.Build quality well above most other brands. i have returned it for an MC-2 global.
    Recommended products
