1 / 5
SUUNTO A-30
SH Metric Compass - SUUNTO US
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS012095014
Suunto A-30
SH Metric Compass
$35
A compact, accurate compass for hiking and orienteering, also in poor visibility.
  • High grade steel needle with jewel bearing
  • Fixed declination correction scale
  • Balanced for southern hemisphere, metric scale
  • Luminescent markings for working in low light
  • Baseplate with magnifying lens
  • Detachable snap-lock lanyard
    Choose Your Color
    Quantity
    $35
    Compare +
    30-Days Return
    Global Support
    SUUNTO A-30 SH Metric Compass
    $35
    Add to cart
    Designed in Finland
    Made in Finland
    Limited lifetime warranty
    Control marking holes
    Exceptionally stable & fast needle
    Luminescent markings for low light
    BASEPLATE COMPASS WITH MAGNIFYING LENS  FOR BACKPACKERS
    Stable operation
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    Specifications
    • Measurements
      114 x 56 x 10 mm / 4.49 x 2.2 x 0.39 "
    • Weight
      32 g / 1.13 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto A-30 SH Metric Compass, lanyard, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    • Liquid filled capsule for stable operation
    • Metric scales
    • Control marking holes
    • Detachable snap-lock lanyard. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      cm, 1:25 000 m, 1:50 000 m
    • Declination correction
      ficed scale
    • Weight
      32 g / 1.13 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      bezel, orienting markings and direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      degrees
    • Needle
      high grade steel
    • Liquid filled and jewel bearing
    • Compass accuracy
      2.5°
    • Compass resolution
      2°
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Magnifying lens
    Recommended products
