1 / 5
SUUNTO A-30
NH Metric Compass - SUUNTO US
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
SUUNTO A-30
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS012095013
Suunto A-30
NH Metric Compass
$35
A baseplate compass for hiking and orienteering, also in poor visibility.
  • High grade steel needle with jewel bearing
  • Exceptionally stable & fast needle
  • Balanced for northern hemisphere, metric scale
  • Luminescent markings for working in low light
  • Baseplate with magnifying lens
  • Detachable snap-lock lanyard
Choose Your Color
Quantity
$35
Compare +
30-Days Return
Global Support
SUUNTO A-30 NH Metric Compass
$35
Add to cart
Designed in Finland
Made in Finland
Limited lifetime warranty
Control marking holes
Luminescent markings for low light
BASEPLATE COMPASS WITH MAGNIFYING LENS  FOR BACKPACKERS
Stable operation
The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
The lanyard with wristlock is easy to detach for working with the map.
Made in Finland
All Suunto compasses are handcrafted at our factory with 100% renewable energy.
Specifications
  • Measurements
    57 x 114 x 10 mm / 2.24 x 4.49 x 0.39 "
  • Weight
    32 g / 1.13 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto A-30 NH Metric Compass, lanyard, Quickrelease, Quick Guide
  • Country of manufacture
    FI
Technical specifications
  • Bezel material:
    Plastic
  • Metric scales
    cm, 1:25 000 km, 1:50 000 km
  • Declination correction
    fixed scale
  • Weight
    32 g / 1.13 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Luminous markings
    bezel, orienting markings and direction of travel
  • Lanyard quick release
  • Attachment
    lanyard
COMPASS
  • Direction scale
    degrees
  • Needle
    high grade steel
  • Liquid filled and jewel bearing
  • Compass accuracy
    2.5°
  • Compass resolution
    2°
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Magnifying lens
Recommended products
