1 / 5
Suunto Nautic Elastic Textile Strap - SUUNTO US
1/5
Money-back guarantee
30-Days Return
Global Support
SKU: SS051303000
Suunto Nautic
$729
Next-generation dive computer for divers who value every moment underwater
Choose Your Color
Quantity
$729
Compare +
30-Days Return
Global Support
$729
Add to cart
Bright AMOLED display, integrated
LED flashlight
Up to 120 hours on a single charge
Wireless tank
pressure
Multi-gas and sidemount support
GPS and underwater route tracking
Suunto App
connectivity
Designed for the depths
For divers who value every moment beneath the surface. Suunto Nautic combines performance, durability, and total reliability in every dive.
It’s the ideal companion for those who explore wrecks, reefs, caves and open water - from dedicated scuba enthusiasts to professional divers who demand precision and trust from their equipment.
Designed in Finland, Nautic reflects Suunto’s decades of dive expertise — ready for every dive, everywhere.
Built for depth, made to endure
Underwater, reliability is everything. Suunto Nautic’s rugged waterproof design withstands the pressure of diving and years of use.
The bright AMOLED display keeps vital information visible at all times, while the tactile buttons are easy to operate even with thick dive gloves. The flexible bungee mount makes Nautic easy to put on and take off, ensuring a secure and comfortable fit with any dive suit. Whether exploring wrecks, reefs, or training at depth, Nautic is made to endure every adventure.
Rugged leak-proof construction
Glove-friendly
buttons
Designed and tested
in Finland
Battery that keeps up, dive after dive
When your adventure takes you deep and long, battery life matters. Suunto Nautic delivers up to 120 hours of dive time on a single charge.
This endurance ensures multiple dives or extended expeditions without worrying about power letting you focus on the experience, not the equipment
Rechargeable battery.
single charge
Reliable power for
multi-day diving trips
Designed for endurance
Made for every dive and every diver
From recreational dives to technical missions, Suunto Nautic grows with your passion.
It supports single- and multi-gas configurations, sidemount setups, and full decompression planning. Customizable dive views let you choose what matters most at every depth. Whatever your dive style, Nautic adapts to it seamlessly.
Multi-gas and
sidemount support
Customizable dive
views
Full decompression
planning
Real-time awareness, wireless precision
Wireless tank pressure tracking gives divers real-time gas readings and consumption data at a glance. Dual transmitter support makes it easy for sidemount divers to follow both tanks simultaneously, while clear, color-coded visuals keep you instantly informed throughout the dive.
Wireless tank
pressure readings
Dual transmitter
support for
sidemount diving
Color-coded visuals
for instant clarity
Stay oriented above and below the surface
Suunto Nautic integrates essential navigation and safety tools to keep you oriented wherever you dive.
Offline maps and GPS help plan and track your routes, while the built-in digital compass provides precise direction underwater. Tide, weather, and sunrise/sunset data support safe surface intervals and the integrated flashlight brings visibility and convenience when light is scarce. Nautic keeps you aware and in control, both underwater and on the surface.
GPS and offline maps
Digital compass for underwater
navigation
LED flashlight, tide, and weather support
for safety
Smart connections, easy control
After your dive, Suunto App brings your experience to life.
Transfer dive logs and routes automatically, analyse performance, and share moments with your dive partners.
Nautic’s smart integration makes it easy to stay connected and track every dive you make.
Automatic dive log
sync
Route and condition tracking
Share and relive
every dive
Explore more with the Suunto app
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Access additional benefits and services from our 200+ partners.
Learn more
Specifications
  • Measurements
    101 x 60 x 23.7 mm / 3,98 x 2.36 x 0.93 "
  • Weight
    232g / 8.18 oz (with elastic textile strap)
  • Bezel material:
    Fiber reinforced polymer
  • Glass material:
    Panda glass (PANDA-MN228 high alumina silicon glass)
  • Case material:
  • Strap material:
    Elastic textile
  • Country of manufacture
    FI
Technical specifications
  • Bezel material:
  • Glass material:
  • Case material:
  • Watch diameter:
    101,34 mm x 65,8 mm
  • Watch thickness:
    26,2 mm
  • Strap material:
    Elastic textile
  • Weight
  • Color display
  • Water resistance
    200 m
  • Vibration alert
  • Battery type
    Rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Stopwatch timer
  • Always-on display
  • Configurable backlight
    Automatic brightness
  • Button lock
  • Backlight
    AMOLED
  • Languages
  • Display size
    3,26''
  • Display type
    Matrix
  • Display resolution
    720 x 382
  • Battery indicator
    Percentage / icon
  • Metric and imperial units
MUSIC
CONNECTIVITY
  • Smartphone compatibility
    Most common models supported, check here for detailed compatibility list
    Bluetooth
  • Compatible with Suunto app
COMPASS
  • Digital compass
  • Tilt compensation
  • Declination correction
  • Direction scale
  • Needle
  • Compass accuracy
    5°
  • Compass resolution
    1°
  • Digital compass during scubadiving
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
  • Operating temperature in dive mode
BATTERY LIFE
  • Battery life (dive)
    80 - 190h
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Offline maps on watch
  • Offline map storage size
    32 GB
  • Satellite systems
  • GNSS frequency support
    Dual band (L1+L5)
  • GPS recording rate
    Best, Good, OK, Low
  • Zoom levels in navigation
  • GPS track analysis
WEATHER
  • Sunrise/sunset times
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
TRAINING FUNCTIONS
HEART RATE
    Bluetooth HR belts
SPORT EXPERTISE
SPORT MODES
    Customizable dive
    In dive
    Dive modes
DIVING FUNCTIONS
FREEDIVING
  • Dive time alarm
  • Depth alarm
BASIC
    200m
  • Nitrox (and air)
  • Gauge
  • Dive time
  • Surface time
  • No fly time
  • Safety Stop
  • Ascent time display
  • CNS/OTU (OLF) calculation
  • Gas time
  • Gas consumption (real-time)
  • Altitude adjustment
  • Gases
    up to 5 gases (Oxygen 21 - 100%)
  • Gas max pO2
    Manual 1.0 - 1.6
  • Timer
  • No-decompression planner
  • Dive history
  • Decompression model
    Suunto Bühlmann 16 GF
  • Wireless air integration
  • Customizable dive modes and displays
  • Personal adjustment
    Gradient factors low (10-100) and high (50-100)
  • Decompression profile options
    Stepped and continuous
  • Dive history
    lifetime
  • Gas switching
  • Deco planner
  • Helium
DIVE ALARMS AND NOTIFICATIONS
  • Too fast ascent
  • CNS/OTU (OLF) 80% / 100%
  • Dive time
  • Gas time
  • High pO2 (hyperoxic)
  • Low pO2 (hyperoxic)
  • Maximum depth
  • Tank pressure
  • NDL
Recommended products
Support for Suunto Nautic
