1 / 9
Suunto MC-2 NH USGS Mirror Compass - SUUNTO US
1/9
Money-back guarantee
30-Days Return
Global Support
SKU: SS004239001
Suunto MC-2
$70
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
  • High grade steel needle with jewel bearing
  • Balanced for northern hemisphere, USGS UTM scales
  • Mirror for sighting bearings and signaling, with magnifying lens
  • Luminescent markings for working in low light
  • Adjustable declination correction
  • Clinometer combined
  • Detachable snap-lock lanyard with wristlock
      Choose Your Color
      Quantity
      $70
      Compare +
      30-Days Return
      Global Support
      $70
      Add to cart
      Designed in Finland
      Made in Finland
      Limited lifetime warranty
      Exceptionally stable & fast needle
      *only available in Steel solar & Titanium solar models
      Baseplate with magnifying lens
      Luminescent markings for low light
      Sighting compass for mountain adventures
      Integrated clinometer
      The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
      The lanyard with wristlock is easy to detach for working with the map.
      Made in Finland
      All Suunto compasses are handcrafted at our factory with 100% renewable energy.
      The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
      Stable operation
      Mirror for more
      The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
      Accurate bearings
      Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
      Specifications
      • Measurements
        65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
      • Weight
        74 g / 2.61 oz
      • Bezel material:
        Plastic
      • What's in the box?
        Suunto MC-2 NH USGS Mirror Compass, lanyard with wristlock and declination correction tool, Quickrelease, Quick Guide
      • Country of manufacture
        FI
      • Liquid filled capsule for stable operation
      • Sighting hole and notch for accurate bearings
      • Clinometer
      • USGS UTM scales
      • Baseplate with magnifying lens
      • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
      • Suunto limited lifetime warranty
      • Made in Finland
      • NSN: 6605-01-546-9503
      Technical specifications
      • Bezel material:
        Plastic
      • Imperial scales
        inch, 1:24 000 mi, 1:24 000 UTM, 1:50 000 UTM
      • Declination correction
        adjustable
      • Weight
        74 g / 2.61 oz
      • Water resistance
        insensitive to water pressure
      • Battery type
        no battery required
      • Luminous markings
        bezel, orienting markings, direction of travel
      • Lanyard quick release
      • Attachment
        lanyard
      COMPASS
      • Direction scale
        degrees
      • Needle
        high grade steel
      • Liquid filled and jewel bearing
      • Compass accuracy
        2.5°
      • Compass resolution
        2°
      PHYSICAL SPECIFICATIONS
      • Operating temperature
      • Storage temperature
      OUTDOOR FUNCTIONS
      GPS TRACKING & NAVIGATION
      • Sighting
        mirror, notch and hole
      • Mirror
      • Magnifying lens
      CLINOMETER
      • Clinometer
      • Liquid filled
      • Clinometer scales
        0 ± 90°
      • Inlcination accuracy
        2°
      • Inclination resolution
        2°
      Recommended products
