SUUNTO M-3 IN - SUUNTO US
Money-back guarantee
30-Days Return
Global Support
SKU: SS004307001
SUUNTO M-3 IN
A premium quality precision compass for convenient direction taking even in demanding conditions
30-Days Return
Global Support
SUUNTO M-3 IN
$0
Out of Stock
THE BASEPLATE COMPASS FOR ADVENTURERS
The adventure compass. A reliable compass is essential for navigating and surviving in extreme conditions. These hardy baseplate compasses are ready for the challenge.
PRODUCT HIGHLIGHTS
  • Adjustable Declination correction
  • Operable in low light with luminescent markings
  • Magnifying lense on transparent baseplate for easy use with map
Specifications
  • Measurements
    120 x 61 x 0 mm / 4.72 x 2.4 x 0 "
  • Weight
    47 g / 1.66 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto M-3 IN, lanyard, declination adjustment key, manual
  • Country of manufacture
    FI
  • Balanced for northern hemisphere
  • Serrated bezel ring
  • Jewel bearing
  • Adjustable declination correction scale
  • Base plate with anti-slip rubber pads and rounded edges
  • Baseplate with magnifying lens
  • Easy-to-read luminous markings help to use the compass in dark conditions
  • Control marking holes
  • Inch scales
Technical specifications
  • Bezel material:
    Plastic
  • Imperial scales
    inch, 1:24 000 mi, 1:62 500 mi, cm
  • Declination correction
    adjustable
  • Weight
    47 g / 1.66 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Luminous markings
    bezel, orienting markings and direction of travel
  • Attachment
    lanyard
COMPASS
  • Direction scale
    degrees
  • Needle
    high grade steel
  • Liquid filled and jewel bearing
  • Compass accuracy
    2.5°
  • Compass resolution
    2°
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Magnifying lens
