Suunto M-3 Global CM - SUUNTO US
Money-back guarantee
30-Days Return
Global Support
SKU: SS004321010
A premium quality precision compass for convenient direction taking globally even in demanding conditions
30-Days Return
Global Support
$9,999.99
Out of Stock
THE BASEPLATE COMPASS FOR GLOBETROTTERS
The adventure compass. A reliable compass is essential for navigating and surviving in extreme conditions. These hardy baseplate compasses are ready for the challenge.
PRODUCT HIGHLIGHTS
  • Fast, globally balanced needle with jewel bearing
  • Adjustable declination correction
  • Operable in low light with luminescent markings
Specifications
  • Measurements
    60 x 125 x 0 mm / 2.36 x 4.92 x 0 "
  • Weight
    44 g / 1.55 oz
  • Bezel material:
    Plastic
  • What's in the box?
    Suunto M-3 Global CM, lanyard, declination adjustment key, manual
  • Country of manufacture
    FI
  • Global Balancing System
  • Serrated bezel ring
  • Jewel bearing
  • cm scale
  • Adjustable declination correction scale
  • Base plate with anti-slip rubber pads and rounded edges
  • Baseplate with magnifying lens
  • Easy-to-read luminous markings help to use the compass in dark conditions
  • Control marking holes
Technical specifications
  • Bezel material:
    Plastic
  • Metric scales
    cm, 1:15 000 km, 1:20 000 km, 1:25 000 km, 1:50 000 km
  • Declination correction
    adjustable
  • Weight
    44 g / 1.55 oz
  • Water resistance
    insensitive to water pressure
  • Battery type
    no battery required
  • Luminous markings
    bezel, orienting markings and direction of travel
  • Attachment
    lanyard
COMPASS
  • Direction scale
    degrees
  • Needle
    Suunto global needle
  • Globally balanced
  • Liquid filled and jewel bearing
  • Compass accuracy
    2°
  • Compass resolution
    2°
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Magnifying lens
CLINOMETER
  • Clinometer
  • Liquid filled
  • Clinometer scales
    0 ± 90°
  • Inlcination accuracy
    2°
  • Inclination resolution
    2°
