1 / 11
Suunto Ambit3 Run Black - SUUNTO US
1/11
SKU: SS021256000
The GPS watch for running with mobile connection
$0
Out of Stock
THE RUNNING EXPERIENCE
Wherever you run, the Suunto Ambit3 Run is optimized for your perfect running experience. The running performance and sleep recovery measurements combined with full route navigation give you the tools to progress and explore.
PRODUCT HIGHLIGHTS
  • The runner's solution for advanced training
  • Smart mobile connection
  • Enrich, relive and share your moves
Specifications
  • Measurements
    50 x 50 x 15.5 mm / 1.97 x 1.97 x 0.61 "
  • Weight
    72 g / 2.54 oz
  • Bezel material:
    Polyamide
  • Glass material:
    Mineral crystal
  • Case material:
    Polyamide
  • Strap material:
    Elastomer
  • What's in the box?
    Suunto Ambit3 Run Black, USB cable, Quick Guide, Warranty Leaflet
  • Country of manufacture
    FI
  • RUNNING AND TRAINING
  • 15h battery with 5 sec-GPS accuracy (1 min-accuracy: 100h)
  • Speed, pace, distance and GPS altitude
  • Route navigation and track back
  • Running cadence from the wrist
  • Running performance indication (Firstbeat)
  • Movescount training programs on the watch
  • Discover new routes with heatmaps on Suunto Movescount
  • Activity based recovery time
  • Quick recovery and sleep recovery tests (Firstbeat)
  • Extended feature set through Suunto Apps
  • Languages: EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
  • CONNECTIVITY
  • Upload and share your moves instantly*
  • Time and GPS satellite data up to date on the go*
  • See calls, messages and push notifications on the watch*
  • Integration with Strava and TrainingPeaks
  • ENRICH, RELIVE AND SHARE
  • Share your experience instantly to your social media networks*
  • with the Suunto app
  • with Suunto Smart Sensor
  • Note! The Ambit3 watches are not compatible with ANT+™ (e.g. Suunto ANT belt, Suunto Dual)
Technical specifications
  • Bezel material:
    Polyamide
  • Glass material:
    Mineral crystal
  • Case material:
    Polyamide
  • Strap material:
    Elastomer
  • Weight
    72 g / 2.54 oz
  • Water resistance
    50 m
  • Battery type
    rechargeable lithium-ion
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Languages
  • Backlight
    LED
  • Configurable backlight
    brightness / mode
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Battery indicator
    percentage / icon
  • Metric and imperial units
  • Autoscrolling of exercise displays
  • Memory left indicator
  • Firmware upgradable
BATTERY LIFE
  • In time mode
    14 days
  • Training mode with GPS
    10, 15, 100 h For more information www.suunto.com/software-updates
CONNECTIVITY
  • Watch customization
    USB cable
    Bluetooth Smart
  • Data transfer
    Wireless / USB cable
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
  • Smartphone compatibility
    iPhone, Android
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    5
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Chrono, GPS, HR, weather and altitude data
    yes, excluding weather
  • Running, cycling, swimming data
    yes, excluding cycling power/swimming
  • Rich math functions, if/then-logic, sound, backlight, etc.
  • Create own metrics with advanced formulas
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
    5°
  • Compass resolution
    1°
  • Declination correction
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS
  • GPS recording rate
    1, 5, 60 s
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Route planning
    in Suunto Movescount.com
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
  • Find back
  • Track back
    yes
ALTIMETER
  • Altitude graph
  • Vertical speed
    GPS based
  • Total ascent/descent
    GPS based only available with best GPS accuracy
  • Altitude difference
    yes** ** available as Suunto Apps
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
  • GPS altitude
TRAINING FUNCTIONS
SPEED AND DISTANCE
  • Distance based autolaps
    1, 10 s
  • Chrono
  • Laps
    > 1000
  • Autopause
  • GPS speed and distance
    Integrated
  • Foot POD support
    Bluetooth Smart
HEART RATE
  • RR interval
  • Heart rate in % of max hr
  • Real-time average and max heart rate
  • Heart rate limits
  • Calories
  • Peak Training Effect
  • Recovery time
  • Real time EPOC
    1, 10 s
  • Speed and heart rate-based guidance during exercise
TRAINING RECOVERY
  • Sleep recovery test (Firstbeat™) For availability information check www.suunto.com/software-updates
  • Quick recovery test (Firstbeat™)
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
SPORT EXPERTISE
SPORT MODES
    10 modes / 8 displays per mode
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Average pace in real time
  • Running cadence
    watch or Foot POD
  • Foot POD calibration
    manual or GPS
  • Average stride length
  • Lap comparisons by kilometer/mile
  • Marathon End-time Estimator
  • Running Performance (Firstbeat™) For availability information check www.suunto.com/software-updates
CYCLING
  • Cycling speed
    based on GPS
  • Average speed in real time
    based on GPS
SWIMMING
  • Openwater swim pace and distance
    Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
SUPPORT FOR SUUNTO AMBIT3 RUN
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
