Navigation improvements and usability improvements released April 23rd, 2014 for Suunto Ambit2 R.
Compass bearing tracking
You will be able to track a bearing easier now with the new bearing lock feature. Press BACK LAP when the compass is active to lock the bearing on the display. The locked bearing indicator can be visually tracked and stays on the display until you press BACK LAP again.
Waypoint navigation simplified
When you are navigating to a waypoint or POI, the bearing is now shown as an absolute bearing from your current location to the waypoint. This used to be relative to your heading. With this new way, you can easily locate yourself on a map when you know your waypoint, the bearing to it, and your distance to it.
Shortcut to menu
If you have a setting that you need to change frequently or just need to get to some menu item quicker, you can create a shortcut by navigating to the location and keeping the VIEW pressed. The shortcut is then active in TIME mode.
Your subheading
Your title
Suunto AI Coach — The coach you always wanted
Suunto AI Coach  ·  New
The coach you
always wanted.
You already know what you did yesterday. Suunto AI Coach helps you decide what to do tomorrow.
Know what to
train
Plans that adapt to your goals and the time you have.
Know where to
go
Routes matched to your fitness and where you are.
Know when to
recover
Readiness from your recovery, sleep and training load.
Key benefits
More than a training plan.
It analyses your training, adapts your plan, guides your recovery and helps you find where to go next.
Builds training around you
Creates and adapts training based on your fitness, goals and available time.
Knows when to push or recover
Analyses your training load, recovery, sleep and activity history before recommending what to do next.
Creates routes for your watch
Ask for a route and it builds one around where you are, then sends it to your watch to navigate.
Answers your questions
Ask naturally about your training, recovery or routes and get answers based on your own data.
Adapts with every activity
Each workout, adventure and recovery period helps your coach better understand what you need.
See it in action
Ask your coach,
almost anything.
Plan a workout, build a route, compare your months or check a trend, all from your own data, right in the Suunto app.
Suunto AI Coach
Your app and watch, as one.
The app does the thinking, your watch gets you moving, and Suunto AI Coach keeps the two in step.
01
Ask, wherever you are
“Find me a local 7k route” or “what should I train today?” On holiday or at home, just ask.
02
AI Coach works it out
It draws on your goals, your training and where you are, for a real answer, not generic advice.
03
Get it where you need it
A route, workout or plan syncs to your watch. An answer or insight stays in the app.
How to get it
Two ways in.
Get a Race 3 series watch
Three months included
Race 3 S and Race 3 come with three months of Suunto AI Coach, whether you’re new to Suunto or upgrading.
Explore the watches
Use your current Suunto
Apply for early access
Already have a compatible Suunto watch? Join the Pioneers Program and try Suunto AI Coach before wider availability.
Supported devices
Get Suunto AI Coach with the Race 3 series.
A Race 3 series watch is the fastest way in, with three months of Suunto AI Coach included.
Suunto Race 3 S
3 months included
Race 3 S
Available first
Lightweight trail performance. 1.32″ AMOLED, dual-band GPS, sapphire crystal.
Explore Race 3 S
Suunto Race 3
3 months included
Race 3
Coming later in 2026
Bigger 1.5″ AMOLED display and longer battery for the long days out.
Explore Race 3
How to activate
Up and running in minutes.
Got a Race 3 series watch? Start your three months of Suunto AI Coach in a few steps.
01
Open the Suunto app
Download or open it, and sign in to your Suunto account.
02
Register your watch
Add your Race 3 series watch and your three-month trial activates automatically.
03
Ask your first question
AI Coach is ready in the app. Ask what to train, or plan a route.
Pricing
Three months included. Continue when you choose.
Your Race 3 series watch includes three months of Suunto AI Coach. Continue with a paid plan after your trial to keep your coaching active.
Explore the Race 3 series
Pioneers Program
Already a Suunto user? Get in early.
Apply to join the Pioneers Program and experience Suunto AI Coach before wider availability. Existing owners with compatible watches come first.
Sign in with your Suunto account
We’ll use your account to confirm your watch and email, nothing to type.
Spots available · limited intake
No Suunto account? Apply with your email
Thanks. You’re on the list, we’ll be in touch.
FAQ
Good to know.
What is Suunto AI Coach?
Suunto AI Coach turns your training, recovery and route data into guidance you can act on. Ask what to train, when to recover, or where to run, and get answers based on your own activity, right in the Suunto app.
How is this different from Suunto Coach?
Suunto Coach builds your structured training plan. Suunto AI Coach is the coach you can talk to: ask questions in your own words and get adaptive guidance across training, recovery and routes, in the moment and from your own data.
Which watches work with it?
At launch, Suunto AI Coach comes with the Race 3 series, Race 3 S and Race 3, with three months included. Owners of other compatible Suunto watches can request early access through the Pioneers Program.
What does it cost?
It is free for three months with a Race 3 series watch. After the trial it continues as a paid plan, planned for 2027. Join the Pioneers Program and we’ll share plan details before launch.
What can I ask it?
Plenty. Plan a workout for today, build a running route, compare this month with last, check a trend like your resting heart rate, or ask whether you’re ready to push. If it relates to your training, recovery or adventures, ask away.
How do I activate it?
Get a Race 3 series watch, open the Suunto app and register it. Your three-month trial activates automatically, so you can start asking straight away.
What data does it use?
Suunto AI Coach works from your own Suunto data, your training, recovery, sleep and routes, to make its guidance personal rather than generic.
What technology is behind Suunto AI Coach?
Suunto AI Coach is built by Suunto and runs inside the Suunto app. It combines your own training, recovery and route data with Suunto’s sports science, so the guidance is personal and relevant rather than generic.
Can I connect my own AI, like ChatGPT?
Suunto AI Coach is designed to work natively with your Suunto data, so you get connected, reliable guidance without handing your training data to outside tools. The focus is a seamless in-app experience rather than plugging in external chatbots.
