1 / 8
Suunto Vertical 2 Pine Green - SUUNTO US
1/8
rotation-icon
Photos
Video
360°View
Money-back guarantee
30-Days Return
Global Support
SKU: SS051207000
Suunto Vertical 2
Pine Green
$599
Ultimate adventure watch for outdoor expeditions and training — improved
  • Bright 1.5'' AMOLED display
  • Up to 65 hours battery
  • 115+ sport modes
  • Integrated LED flashlight
  • Improved heart rate tracking
🎁Add to Cart to Unlock Your FREE Strap
*Offer only works via "Add to cart", "Buy now" will not apply.
*Cannot be combined with ProClub, ExpertVoice, or one-time discount codes.
Choose Your Color
Quantity
$599
30-Days Return
Global Support
$599
Add to cart
Bright 1.5” AMOLED display
115+ sport modes
Designed for the adventure
For adventurers who demand the best when testing their limits — far from the trailhead and cell service.
The Suunto Vertical 2 improves upon the original with a brighter, larger AMOLED screen, a redesigned optical heart rate sensor coupled with a flat-lay backpanel for a better fit, and a built-in LED flashlight that provides safety and convenience after dark; all stacked on top of the weeks-on-end battery life, advanced navigation tools, and tough design that the Vertical family is known for. From planning and training to execution, Suunto Vertical 2 is made to explore new frontiers.
Built to endure
When you're in the thick of it, you need equipment you can trust without hesitation. The Suunto Vertical 2 shrugs off scrapes and scratches during rocky ascents, and forges confidently in downpours thanks to water resistance down to 100m. Easily navigate in low and bright light with the larger, brighter AMOLED display, while the interface is easily operable — without removing your gloves — at the push of a button. This is your adventure watch to get out there, no matter the weather or environment.
Rugged design in titanium or steel
Secure fit silicone straps
Designed and tested in Finland
Battery for your longest missions
For multi-day expeditions or self-supported adventure racing, you need a battery that can go the distance. Suunto Vertical 2 delivers up to 65 hours of training time in the most accurate GPS mode and up to 20 days of daily smartwatch use. This extended battery life is designed to keep you going further, longer.
Training, continuous tracking
Up to 65 hours
Up to 250 hours
Up to 20 days
Up to 30 days
A mode for every adventure
Months of preparation go into your expedition, and Suunto Vertical 2 will be with you every step and training along the way. With over 115 sport modes, you can track your everyday workouts — from trail running and backcountry skiing to mountain biking and swimming — to stay on target.
Whatever your passion, this high-performance companion is designed to support every aspect of your active life, on the trail and off.
115+ sport modes
Training Zone with AI Coach
Workout planning
Navigate off-grid, offline
Seek uncharted terrain, but have the confidence you can get back with Suunto's trusted navigation tools. Free, high-detail offline maps and a dual-band GPS keep you on track.
Advanced features like sport-specific heatmaps let you find popular routes (or steer clear of them) while Climb Guidance helps you plan for elevation, gradient, and surface changes on the trail ahead. Off-grid, high-altitude, remotest of remote — Suunto Vertical 2 takes you there.
Route planning with heatmaps
Climb Guidance planning tool
Dual-band GPS system
A smart way to prepare and progress
Prepare for your Type 2 adventure with smart planning and progress tracking. The redesigned backpanel creates a better connection for the upgraded OHR sensor so you can train more efficiently with improved blood oxygen readings, HRV measurements, and sleep tracking. Post-session, the Training Zone and Suunto Coach features help you analyse your progress and provide evolving guidance, ensuring you're ready for the next challenge.
A watch that evolves with you
Your ambition doesn’t stand still, and neither should your watch. We designed Suunto Vertical 2 with faster hardware for one key reason: to ensure it’s ready for the adventure ahead - full of new features and plenty of software updates to come.
Coupled with our growing ecosystem of partner apps, like Strava and Komoot, Vertical 2 is built to grow and evolve alongside you.
For more info, check out what all the Suunto App can offer you.
300+ partner apps
Growing app ecosystem
Faster hardware, more memory
0 / 0
Suunto app
Learn more
SuuntoPlus™
Learn more
Partners
Partners Learn more
Specifications
  • Measurements
    48.6 x 48.6 x 13.5 mm / 1.91 x 1.91 x 0.53 "
  • Weight
    87 g / 3.07 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Sapphire crystal
  • Case material:
  • Strap material:
    Silicone
  • What's in the box?
    Suunto Vertical 2, charging cable, printed user documentation
  • Country of manufacture
    CN
Technical specifications
  • Bezel material:
    Stainless steel
  • Glass material:
    Sapphire crystal
  • Case material:
  • Strap material:
    Silicone
  • Weight
    87 g / 3.07 oz
  • Wrist sizes:
    125-175 mm
  • Integrated wrist heart rate
  • Customizable watch faces
  • Touch screen lock
  • Touch display
  • Color display
  • Vibration alert
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Languages
    CS, DA, DE, EL, EN, ES, FI, FR, HE, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, ZH*, TH*, ZHTW*.
  • Backlight
    LTPO AMOLED
  • Configurable backlight
    automatic brightness
  • Button lock
    during exercise
  • Display size
    1,5''
  • Display type
    Matrix
  • Display resolution
    466 x 466
  • Battery indicator
    percentage / icon
  • Metric and imperial units
  • Blood oxygen
  • Strap width:
    22 mm
  • Outdoor offline map storage
    32GB
  • Always-on display
CONNECTIVITY
  • Smartphone compatibility
    Most common models supported
    Bluetooth
  • Music/Media controls on watch
  • Send predefined answers to incoming messages from watch
    Android only
    Strava, TrainingPeaks and many more
  • Compatible with Suunto app
COMPASS
  • Digital compass
  • Tilt compensation
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
  • Declination correction
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • Daily use: Smartwatch mode
    up to 20 days
    up to 40 days
    up to 65h (AOD 60h)
    up to 75h (AOD 70h)
    65h / 75h / 110h / 250h
    up to 250h
DIVING FUNCTIONS
FREEDIVING
  • Depth meter for snorkeling
    10 m
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    4
  • Max connected satellites
    32
  • GPS recording rate
    Best, Good, OK, Low
  • Intelligent battery modes
  • Zoom levels in navigation
  • Snap to route
  • GPS track analysis
  • Offline maps on watch
  • GNSS frequency support
    L1 + L5
  • Offline map storage size
    32 GB
  • ETA (estimated time of arrival), remaining distance
ALTIMETER
  • Barometric altitude
  • GPS altitude
  • Altitude in daily mode
  • Total ascent/descent
  • Vertical speed
  • Automatic alti/baro profile
  • Log recording rate
    1 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sunrise/sunset times
  • Storm alarm
  • Sea level pressure
  • Temperature
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
  • Pressure resolution
    1 hPa
  • Move altitude graph in Move summary
TRAINING FUNCTIONS
INTERVAL TRAINING
  • Setup intervals
  • Structured intervals
HEART RATE
    Bluetooth HR belts
  • RR interval
    with Suunto Smart Sensor
  • Calories
  • Peak Training Effect
  • Recovery time
  • Personal heart rate zones
  • Lactate threshold detection
  • Fitness level (VO2max)
TRAINING LOAD
TRAINING RECOVERY
SHARE AND RELIVE
SPEED AND DISTANCE
  • GPS speed and distance
  • Chrono
  • Foot POD support
    Bluetooth Foot Pods
  • Autolaps
  • Manual laps
24/7
ACTIVITY TRACKING
  • Step counter
  • Calories burned
  • Activity targets
    Steps, Calories
  • Activity history
SLEEP TRACKING
  • Sleep duration
  • Bed times
  • Sleep quality
  • Time awake
  • Deep sleep
  • HRV from sleep
  • REM
  • Light sleep
STRESS AND RECOVERY
  • Daily resource level
  • Stress and recovery status
  • HRV measurement
SPORT EXPERTISE
MULTISPORTS
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Snap to route
  • Running power
  • SuuntoPlus™ Ghost runner
  • Foot POD calibration
    automatic
CYCLING
  • Cycling speed
  • Average speed in real time
    Bluetooth Bike Pods
  • Bike power meter support
    Bluetooth Power meters
SWIMMING
  • Pool swim pace and distance
  • Openwater swim distance
  • Stroke efficiency (SWOLF)
  • Automatic intervals
  • Interval lap table
SPORT MODES
  • Graph displays in sport modes
    > 90
  • SuuntoPlus™
Recommended Products
SUPPORT FOR SUUNTO VERTICAL 2
