Suunto Run 2
Aloe Green 4GB
- New-Generation GPS
- Real-Time Run Insights
- 2,000-Nit Bright Display
- 35 g* Nordic Lightweight Design
- Upgraded Heart Rate
- 10-Day Daily Battery
Choose Your Color
See the Run Ahead
A breakthrough is shaped long before the finish line. It's built in decisions made early enough to matter. Hold, or push. Adjust, or recover. Every one of them gets easier when you can see clearly. What your effort is costing. Where your pace is taking you. How much you still have in you. Thirty‑five grams on your wrist, from the first kilometre to the last night's sleep. Readable in full sun, at full stride. Numbers steady enough to build a race plan on. So when the finish comes into view, you already knew it was coming.
The lightest part of your run
At 35 g*, the watch body sits close enough to the wrist that you stop registering it — through long runs, through sleep, through the rest of the day. A stainless steel bezel, Gorilla Glass, and 5 ATM water resistance keep it ready for all of it, so training, recovery, and sleep arrive as one complete picture instead of a partial one.
Bright enough to run by
Pace, heart rate, and distance stay readable in direct sun, so checking a number costs a look rather than a break in rhythm.
Train all week, Charge once
Top up once a week and keep Suunto Run 2 on through the night, so the record of your training stays continuous rather than starting over after every charge.
The track matches the run
Suunto Run 2 upgrades to dual-band L1 + L5 positioning across GPS, GLONASS, Galileo, BeiDou, and QZSS. Distance, pace, and the track you record sit closer to the route you actually ran, which is what makes the numbers worth executing a training or race plan on.
A steadier read on your effort
A 12-channel sensor behind 2.5D curved glass gathers more signal at the wrist, so heart rate keeps up with hard intervals, surges, and long efforts in the heat. The effort you feel and the effort Suunto Run 2 reports stay in step, which is what makes it worth training by.
See where your effort is taking you
The next turn, already on your wrist
Download free worldwide maps to Suunto Run 2 before you head out. On a travel run or an unfamiliar route, roads, place names, and your surroundings stay on the wrist, so the next turn is a glance away rather than a stop and a phone. The same maps carry onto trail sections when the road runs out.
Run with Music
Load music onto Suunto Run 2 and play them straight from the watch. Long runs head out with everything already on your wrist, so the session belongs to the run and the playlist alone.
What's New in Suunto Run 2
Suunto Run 2 |
Suunto Run |
| Size | 46 x 46 x 11.7mm | 46 x 46 x 11.5 mm |
| Size | ||
| 46 x 46 x 11.7mm | 46 x 46 x 11.5 mm | |
| Screen | 2000nit 1.32’’ AMOLED | 600nit 1.32’’ AMOLED |
| Screen | ||
| 2000nit 1.32’’ AMOLED | 600nit 1.32’’ AMOLED | |
| Battery Capacity | 380 mAh | 295 mAh |
| Battery Capacity | ||
| 380 mAh | 295 mAh | |
| Battery Life (Daily Use) | 10 days | 8 days |
| Battery Life (Daily Use) | ||
| 10 days | 8 days | |
| Battery Life (High Performance) | 24h | 20h |
| Battery Life (High Performance) | ||
| 24h | 20h | |
| Offline Maps | YES | NO |
| Offline Maps | ||
| YES | NO | |
| GPS & Heart rate | Upgraded version | Old version |
| GPS & Heart rate | ||
| Upgraded version | Old version | |
| Storage | 4 / 64 GB | 4 GB |
| Storage | ||
| 4 / 64 GB | 4 GB | |
IN THE BOX
- 1 Suunto Run 2 Watch
- 2 Suunto 22mm Athletic 6 Silicone Strap for Sizes (S/M)
- 3 Quick Guide
- 4 USB-C Charging Cable
- 5 Product Safety & Regulatory Information International Limited Warranty
Specifications
Measurements46 x 46 x 11.7 mm / 1.83 x 1.83 x 0.46
Weight53g (Case 35 g*)
Bezel material:Stainless steel
Glass material:Gorilla glass
Case material:Glass fibre reinforced polyamide
Strap material:silicone
What's in the box?Suunto Run 2, charging cable, printed user documentation
Country of manufactureCN
Technical specifications
Battery typerechargeable lithium-ion
Strap width:22 mm
Wrist sizes:130-200 mm
Watch diameter46mm
Watch thickness11,7mm
Water resistance5 ATM
Battery indicatorpercentage / icon
BacklightAMOLED
Configurable backlightAutomatic brightness
Button lockduring exercise
Display size1.32″
Display typematrix
Display resolution466 x 466
CONNECTIVITY
Connectivity (between devices)Bluetooth
Compatible with online sports communitiesStrava, TrainingPeaks and many more
Automatic over the air software updates✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +55° C / -5° F to +130° F
Storage temperature-20° C to +55° C / -5° F to +130° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
Training: All-Systems GNSS mode + Multi-Bandup to 24h (AOD 18)
Training: All-Systems GNSS mode + Single-Bandup to 30h (AOD 24)
Training: Power saving GNSS modesup to 40h
Daily use: Smartwatch modeup to 13 days
COMPASS
Direction scaledegrees / mils
Needlenorth indicator
Compass accuracy5°
Compass resolution1°
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS, GALILEO, QZSS, BEIDOU
GNSS frequency supportDual band (L1+L5)
Simultaneous satellite systems4
Max connected satellites32
Intelligent battery modesPerformance, Endurance, Power saving
GPS recording rateBest, Good, Low
Offline maps on watch✔
Offline map storage size4GB (Standard, maps+music)/64GB (Premium, maps+music)
WEATHER
Temperature display range-20° C to +55° C / -5° F to +130° F
Temperature resolution1° C / 1.5° F
Pressure resolution1 hPa
ALTIMETER
Log recording rate1 s
Resolution1 m
Range-500 - 9999 m
OTHER FEATURES
Pre-installed sport modes on watch>32
Activity targetssteps, calories
Exercise Volume Assessment✔
Exercise Recovery Assessment✔
Fitness Progress Assessment✔
Adaptive training insightsIn Suunto app
FAQ
With dual-frequency, all-constellation GPS it lasts about 24 hours, enough for a full marathon plus the training around it. In everyday use it goes several days, and longer again in battery-saver mode.
This one's exclusive to Suunto. As you run, the watch works out your projected finish time in real time from your current pace, the route's elevation, the distance you've covered, and your fitness, so you can adjust your pacing on the fly. Your actual finish still depends on weather, terrain, hydration, and how you're feeling, so treat it as a guide.
There's a whole set: a Virtual Pacer mode, Race mode, and target modes for time, distance, ascent, and calories, among others. Guided workouts are supported too.
Yes. The Run series has its own Marathon mode, which adds dedicated data screens on top of the standard running view, including your finish prediction and remaining energy.
Yes. You can ping your phone to make it ring, and control music playback on your phone, including play, pause, skipping tracks, and volume.
It's water resistant to 5 ATM (50 m), which covers swimming, showering, and running in the rain. It isn't made for snorkeling, scuba diving, or diving off boards. Rinse it with fresh water after you swim.
There are 35 sport modes. Running is the focus, with road, trail, treadmill, and track, but you also get cycling, swimming, hiking, gym, triathlon, and more.
Yes. The heart rate sensor is all-new and much steadier during exercise.
