1 / 4
Suunto Run 2 All Black
1/4
Money-back guarantee
30-Days Return
Warranty Repair
SKU: SS051639000
Suunto Run 2
All Black 64GB
$399
Lightweight Running Watch for Your Next Breakthrough
  • New-Generation GPS
  • Real-Time Run Insights
  • 2,000-Nit Bright Display
  • 35 g* Nordic Lightweight Design
  • Upgraded Heart Rate
  • 10-Day Daily Battery
    Choose Your Color
    Quantity
    $399
    Compare +
    30-Days Return
    Warranty Repair
    $399
    Add to cart
    New-Generation GPS
    Upgraded Heart Rate
    See the Run Ahead
    A breakthrough is shaped long before the finish line. It's built in decisions made early enough to matter. Hold, or push. Adjust, or recover. Every one of them gets easier when you can see clearly. What your effort is costing. Where your pace is taking you. How much you still have in you. Thirty‑five grams on your wrist, from the first kilometre to the last night's sleep. Readable in full sun, at full stride. Numbers steady enough to build a race plan on. So when the finish comes into view, you already knew it was coming.
    The lightest part of your run
    At 35 g*, the watch body sits close enough to the wrist that you stop registering it — through long runs, through sleep, through the rest of the day. A stainless steel bezel, Gorilla Glass, and 5 ATM water resistance keep it ready for all of it, so training, recovery, and sleep arrive as one complete picture instead of a partial one.
    35 g* / Body Weight
    Stainless Steel / Bezel
    Gorilla Glass / Lens
    Bright enough to run by
    Clear at a glance
    Pace, heart rate, and distance stay readable in direct sun, so checking a number costs a look rather than a break in rhythm.
    2,000 NITS / Brightness
    1.32 INCH / Display Size
    LTPS AMOLED / Panel Type
    Train all week, Charge once
    Charging fits around you
    Top up once a week and keep Suunto Run 2 on through the night, so the record of your training stays continuous rather than starting over after every charge.
    10 Days / Daily Training Use
    24 HRS / Dual-Band GPS
    +29% / Battery Capacity vs. Suunto Run
    The track matches the run
    New-Generation Navigation
    Suunto Run 2 upgrades to dual-band L1 + L5 positioning across GPS, GLONASS, Galileo, BeiDou, and QZSS. Distance, pace, and the track you record sit closer to the route you actually ran, which is what makes the numbers worth executing a training or race plan on.
    A steadier read on your effort
    Upgraded Heart Rate
    A 12-channel sensor behind 2.5D curved glass gathers more signal at the wrist, so heart rate keeps up with hard intervals, surges, and long efforts in the heat. The effort you feel and the effort Suunto Run 2 reports stay in step, which is what makes it worth training by.
    12-Channel / Wrist HR
    2.5D / Curved Sensor Glass
    24/7 / HR Tracking
    See where your effort is taking you
    EnergySense
    EnergySense reads how hard you are working right now against how much you still have, live on the wrist. Deep into a long run or the back half of a race, holding, easing, or pushing becomes a decision you make based on what you can see rather than on feel alone.
    Marathon Time
    Marathon Time turns your current pace into a finishing time and keeps updating it as you run. When the target starts to slip, you see it early, while there is still road left to hold, adjust, or push.
    The next turn, already on your wrist
    Free Offline Maps
    Download free worldwide maps to Suunto Run 2 before you head out. On a travel run or an unfamiliar route, roads, place names, and your surroundings stay on the wrist, so the next turn is a glance away rather than a stop and a phone. The same maps carry onto trail sections when the road runs out.
    Run with Music
    Offline Playback
    Load music onto Suunto Run 2 and play them straight from the watch. Long runs head out with everything already on your wrist, so the session belongs to the run and the playlist alone.
    What's New in Suunto Run 2
    Suunto Run 2
    Suunto Run 2
    Suunto Run
    Suunto Run
    Size 46 x 46 x 11.7mm 46 x 46 x 11.5 mm
    Size
    Screen 2000nit 1.32’’ AMOLED 600nit 1.32’’ AMOLED
    Screen
    Battery Capacity 380 mAh 295 mAh
    Battery Capacity
    380 mAh 295 mAh
    Battery Life (Daily Use) 10 days 8 days
    10 days 8 days
    Battery Life (High Performance) 24h 20h
    24h 20h
    Offline Maps YES NO
    Offline Maps
    YES NO
    GPS & Heart rate Upgraded version Old version
    GPS & Heart rate
    Storage 4 / 64 GB 4 GB
    Storage
    4 / 64 GB 4 GB
    IN THE BOX
    • 1 Suunto Run 2 Watch
    • 2 Suunto 22mm Athletic 6 Silicone Strap for Sizes (S/M)
    • 3 Quick Guide
    • 4 USB-C Charging Cable
    • 5 Product Safety & Regulatory Information International Limited Warranty
    Specifications
    • Measurements
      46 x 46 x 11.7 mm / 1.83 x 1.83 x 0.46
    • Weight
      53g (Case 35 g*)
    • Bezel material:
      Stainless steel
    • Glass material:
      Gorilla glass
    • Case material:
    • Strap material:
      silicone
    • What's in the box?
      Suunto Run 2, charging cable, printed user documentation
    • Country of manufacture
      CN
    Technical specifications
    • Bezel material:
      Stainless steel
    • Glass material:
      Gorilla glass
    • Case material:
    • Strap material:
      silicone
    • Weight
      53g (Case 35 g*)
    • Battery type
      rechargeable lithium-ion
    • Strap width:
      22 mm
    • Wrist sizes:
      130-200 mm
    • Watch diameter
      46mm
    • Watch thickness
      11,7mm
    • Water resistance
      5 ATM
    • Battery indicator
      percentage / icon
    • Backlight
      AMOLED
    • Configurable backlight
      Automatic brightness
    • Button lock
      during exercise
    • Display size
      1.32″
    • Display type
      matrix
    • Display resolution
      466 x 466
    CONNECTIVITY
      Bluetooth
      Strava, TrainingPeaks and many more
    PHYSICAL SPECIFICATIONS
    • Operating temperature
    • Storage temperature
    BATTERY LIFE
      up to 24h (AOD 18)
      up to 30h (AOD 24)
      up to 40h
    • Daily use: Smartwatch mode
      up to 13 days
    COMPASS
    • Direction scale
      degrees / mils
    • Needle
      north indicator
    • Compass accuracy
      5°
    • Compass resolution
      1°
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Satellite systems
    • GNSS frequency support
      Dual band (L1+L5)
      4
    • Max connected satellites
      32
    • Intelligent battery modes
      Performance, Endurance, Power saving
    • GPS recording rate
      Best, Good, Low
    • Offline maps on watch
    • Offline map storage size
      4GB (Standard, maps+music)/64GB (Premium, maps+music)
    WEATHER
    • Temperature display range
    • Temperature resolution
      1° C / 1.5° F
    • Pressure resolution
      1 hPa
    ALTIMETER
    • Log recording rate
      1 s
    • Resolution
      1 m
    • Range
      -500 - 9999 m
    OTHER FEATURES
      >32
    • Activity targets
      steps, calories
    • Exercise Volume Assessment
    • Exercise Recovery Assessment
    • Fitness Progress Assessment
    • Adaptive training insights
      In Suunto app
    FAQ
    Product overview
    [8]
    Product overview[8]
    Product overview
    [8]
    How long does the battery last?
    With dual-frequency, all-constellation GPS it lasts about 24 hours, enough for a full marathon plus the training around it. In everyday use it goes several days, and longer again in battery-saver mode.
    What is real-time marathon prediction?
    This one's exclusive to Suunto. As you run, the watch works out your projected finish time in real time from your current pace, the route's elevation, the distance you've covered, and your fitness, so you can adjust your pacing on the fly. Your actual finish still depends on weather, terrain, hydration, and how you're feeling, so treat it as a guide.
    What marathon training tools does it have?
    There's a whole set: a Virtual Pacer mode, Race mode, and target modes for time, distance, ascent, and calories, among others. Guided workouts are supported too.
    Is there a dedicated marathon mode?
    Yes. The Run series has its own Marathon mode, which adds dedicated data screens on top of the standard running view, including your finish prediction and remaining energy.
    Can it find my phone and control music?
    Yes. You can ping your phone to make it ring, and control music playback on your phone, including play, pause, skipping tracks, and volume.
    How water resistant is it?
    It's water resistant to 5 ATM (50 m), which covers swimming, showering, and running in the rain. It isn't made for snorkeling, scuba diving, or diving off boards. Rinse it with fresh water after you swim.
    How many sport modes does it have?
    There are 35 sport modes. Running is the focus, with road, trail, treadmill, and track, but you also get cycling, swimming, hiking, gym, triathlon, and more.
    Is the heart rate accurate?
    Yes. The heart rate sensor is all-new and much steadier during exercise.
    Recommended products
    SUPPORT FOR SUUNTO RUN 2
