Out of Stock
1 / 4
Suunto D5 Wildberry - SUUNTO US
1/4
Money-back guarantee
30-Days Return
Global Support
SKU: SS051084000
Suunto D5
Wildberry
$649
An easy-to-use dive computer with interchangeable straps that fit your style. Made in Finland.
Choose Your Color
Quantity
$649
Out of Stock
Compare +
30-Days Return
Global Support
Suunto D5 Wildberry
$649
Out of Stock
Wireless tank pressure support
Extensive scuba and freedive features
Digital compass
Wireless mobile connection
Vibration alarms
Rechargeable battery
Diving life made easy
Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
iF Design Awards 2020
BENEFITS
EASY TO USE
Follow your dive details on the super clear, high contrast color screen. Choose from 3 dive modes and browse the simple yet intuitive menu with three buttons to easily switch between views and settings. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Keep your device easily up-to-date with SuuntoLink and make your dive life one step easier.
DIVING LIFE MADE EASY
Pair your Suunto D5 with Suunto app and stay connected with the diving community and the non-diving life of yours. Receive notifications to your mobile of the applications you use and never miss an adventure.
Transfer your dive logs over Bluetooth to build an all-inclusive dive history to relive and share with your friends. With the location feature every dive and adventure is always on the map.
Suunto app is available in the App Store and Google Play.
MATCH WITH YOUR STYLE
Change the strap easily with the clever quick release system to fit your style. Choose a color that matches your diving gear, or pick your favorite color silicone or leather strap to complete your casual style. To support your everyday usage, an analog watch face is now available for those appreciating the classic style.
WIRELESS CONNECTIVITY
Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto D5 with the Suunto Tank POD before diving. After dive review your gas consumption (when using Suunto Tank POD) in Suunto app and improve your diving.
Specifications
  • Measurements
    53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
  • Weight
    90 g / 3.17 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Mineral crystal
  • Case material:
    Reinforced composite
  • Strap material:
    Silicone
  • What's in the box?
    Suunto D5 Wildberry, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
  • Country of manufacture
    FI
Technical specifications
  • Bezel material:
    Stainless steel
  • Glass material:
    Mineral crystal
  • Case material:
  • Strap material:
    Silicone
  • Weight
    90 g / 3.17 oz
  • Water resistance
    100 m (ISO 6425, EN 13319)
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Stopwatch timer
  • Vibration alert
  • Backlight
    LED
  • Configurable backlight
  • Display resolution
    320 x 300
  • Battery indicator
    icon + dive hours remaining
  • Metric and imperial units
  • Display type
    Memory in pixel
  • Languages
CONNECTIVITY
  • Smartphone compatibility
    Most common models supported
    inductive (Tank POD), Bluetooth Smart
  • Compatible with DM5
  • Log transfer
    Bluetooth Smart / USB cable
  • Watch customization
    Customizable with DM5
  • Compatible with Suunto app
COMPASS
  • Digital compass
  • Tilt compensation
    up to 45°
  • Declination correction
  • Direction scale
    degrees
  • Needle
    compass rose
  • Globally balanced
  • Compass resolution
    1°
  • Compass accuracy
    +/- 15°
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
BATTERY LIFE
  • Battery life (dive)
    up to 6-12 h of diving fully charged or up to 6 days in time mode
DIVING FUNCTIONS
BASIC
  • Nitrox (and air)
  • Freedive
  • Gauge
  • Dive time
    0 to 999 min
  • Surface time
    0 to 100 h
  • No fly time
  • Safety Stop
  • Deep Stop
  • Ascent time display
    0 - 999 min ( > after 999)
  • CNS/OTU (OLF) calculation
  • Gas time
  • Gas consumption (real-time)
  • Visual style
    Graphical
  • Personal adjustment
    P+2, P+1, P0, P-1, P-2
  • Altitude adjustment
  • Gases
  • Gas max pO2
    1.6
  • Timer
  • No-decompression planner
  • Logbook bookmarks
  • Dive history
    lifetime
  • Decompression model
    Suunto Fused™ RGBM 2
  • Logbook sampling rates
    scubadive 10s, freedive 1s
  • Wireless air integration
    optional (up to 3 different tanks with Suunto Tank POD)
  • Logbook memory
  • Customizable dive modes and displays
DIVE ALARMS AND NOTIFICATIONS
  • Dive time
  • Maximum depth
  • Tank pressure
  • Gas time
  • High pO2 (hyperoxic)
  • Too fast ascent
  • Deepstop violation
  • CNS/OTU (OLF) 80% / 100%
FREEDIVING
  • Freedive number
  • Freedive day history
  • Freedive total history
    lifetime
  • Depth notify
    yes (5)
  • Dive time alarm
  • Depth alarm
  • Surface time notify
OUTDOOR FUNCTIONS
WEATHER
  • Temperature
  • Temperature resolution
    1° C / 1.5° F
  • Temperature display range
    -20 to +50 °C/-4 to +122 °F
Recommended products
VIDEOS
You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
Learn how to set depth notifies and a surface notify to use Suunto D5 for advanced free diving.
Learn how to pair your Suunto D5 with the Suunto app for Android and how to get started with the app.
Learn how to pair your Suunto D5 with the Suunto app for iOS and how to get started with the app.
Learn how to use the compass bearing of your Suunto D5.
DM5 is Suunto’s desktop software to customize and update the firmware of your dive computer. DM5 offers various customization options for Suunto D5.
SUPPORT FOR SUUNTO D5
