Out of Stock
1 / 11
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
SUUNTO D5
Copper - SUUNTO US
1/11
Money-back guarantee
30-Days Return
Global Support
SKU: SS050569000
Suunto D5
Copper
$649
Easy-to-use dive computer with interchangeable straps.
  • Mineral crystal color display screen with aluminum bezel
  • Dive functions, and digital compass features with Suunto Fused™ RGBM 2 decompression model
  • Maximum operating depth up to 100m
  • Up to 6-12 hours of battery life in diving mode
  • 5 dive modes(air, nitrox, free,gauge and off)
  • Customizable dive modes for your own display
  • Display up to 3 tank pressures with Suunto Tank Pod
      Choose Your Color
      Quantity
      $649
      Out of Stock
      Compare +
      30-Days Return
      Global Support
      SUUNTO D5 Copper
      $649
      Out of Stock
      Wireless tank pressure support
      Extensive scuba and freedive features
      Digital compass
      Wireless mobile connection
      Vibration alarms
      Rechargeable battery
      Diving life made easy
      Suunto D5 is designed to be so clear and easy-to-use that you can just enjoy and focus on exploring the wonderful underwater world. When not diving, connect wirelessly to Suunto app and receive notifications from the applications you use. Play with style by choosing your favorite color or just by simply changing the straps to match your looks. Suunto D5 connects your two lives: the adventure under the surface but also the great experiences you can relive and share with your friends afterwards.
      iF Design Awards 2020
      BENEFITS
      EASY TO USE
      Follow your dive details on the super clear, high contrast color screen. Choose from 3 dive modes and browse the simple yet intuitive menu with three buttons to easily switch between views and settings. You can easily customize your own dive modes in Suunto app. Choose from different view styles and select the details you want to see while diving. By customizing your dive modes you can also define your settings regarding gas, algorithm and dive alarms. Keep your device easily up-to-date with SuuntoLink and make your dive life one step easier.
      DIVING LIFE MADE EASY
      Pair your Suunto D5 with Suunto app and stay connected with the diving community and the non-diving life of yours. Receive notifications to your mobile of the applications you use and never miss an adventure.
      Transfer your dive logs over Bluetooth to build an all-inclusive dive history to relive and share with your friends. With the location feature every dive and adventure is always on the map.
      Suunto app is available in the App Store and Google Play.
      MATCH WITH YOUR STYLE
      Change the strap easily with the clever quick release system to fit your style. Choose a color that matches your diving gear, or pick your favorite color silicone or leather strap to complete your casual style. To support your everyday usage, an analog watch face is now available for those appreciating the classic style.
      WIRELESS CONNECTIVITY
      Follow your gas pressure conveniently straight from your wrist. Get tank pressure on your display wirelessly by pairing your Suunto D5 with the Suunto Tank POD before diving. After dive review your gas consumption (when using Suunto Tank POD) in Suunto app and improve your diving.
      Specifications
      • Measurements
        53 x 53 x 16.3 mm / 2.09 x 2.09 x 0.64 "
      • Weight
        90 g / 3.17 oz
      • Bezel material:
        Stainless steel
      • Glass material:
        Mineral crystal
      • Case material:
        Reinforced composite
      • Strap material:
        Silicone
      • What's in the box?
        Suunto D5 Copper, USB Cable, Quick Guide, Safety leaflet, Display scratch guard sticker, International warranty leaflet, Suunto sticker
      • Country of manufacture
        FI
      Technical specifications
      • Bezel material:
        Stainless steel
      • Glass material:
        Mineral crystal
      • Case material:
      • Strap material:
        Silicone
      • Weight
        90 g / 3.17 oz
      • Water resistance
        100 m (ISO 6425, EN 13319)
      • Battery type
        rechargeable lithium-ion
      • Firmware upgradable
      • Time, date
      • Alarm clock
        1 daily alarm
      • Dual time
      • Stopwatch timer
      • Vibration alert
      • Backlight
        LED
      • Configurable backlight
      • Display resolution
        320 x 300
      • Battery indicator
        icon + dive hours remaining
      • Metric and imperial units
      • Display type
        Memory in pixel
      • Languages
      CONNECTIVITY
      • Smartphone compatibility
        Most common models supported
        inductive (Tank POD), Bluetooth Smart
      • Compatible with DM5
      • Log transfer
        Bluetooth Smart / USB cable
      • Watch customization
        Customizable with DM5
      • Compatible with Suunto app
      COMPASS
      • Digital compass
      • Tilt compensation
        up to 45°
      • Declination correction
      • Direction scale
        degrees
      • Needle
        compass rose
      • Globally balanced
      • Compass resolution
        1°
      • Compass accuracy
        +/- 15°
      PHYSICAL SPECIFICATIONS
      • Operating temperature
      • Storage temperature
      BATTERY LIFE
      • Battery life (dive)
        up to 6-12 h of diving fully charged or up to 6 days in time mode
      DIVING FUNCTIONS
      BASIC
      • Nitrox (and air)
      • Freedive
      • Gauge
      • Dive time
        0 to 999 min
      • Surface time
        0 to 100 h
      • No fly time
      • Safety Stop
      • Deep Stop
      • Ascent time display
        0 - 999 min ( > after 999)
      • CNS/OTU (OLF) calculation
      • Gas time
      • Gas consumption (real-time)
      • Visual style
        Graphical
      • Personal adjustment
        P+2, P+1, P0, P-1, P-2
      • Altitude adjustment
      • Gases
      • Gas max pO2
        1.6
      • Timer
      • No-decompression planner
      • Logbook bookmarks
      • Dive history
        lifetime
      • Decompression model
      • Logbook sampling rates
        scubadive 10s, freedive 1s
      • Wireless air integration
        optional (up to 3 different tanks with Suunto Tank POD)
      • Logbook memory
      • Customizable dive modes and displays
      DIVE ALARMS AND NOTIFICATIONS
      • Dive time
      • Maximum depth
      • Tank pressure
      • Gas time
      • High pO2 (hyperoxic)
      • Too fast ascent
      • Deepstop violation
      • CNS/OTU (OLF) 80% / 100%
      FREEDIVING
      • Freedive number
      • Freedive day history
      • Freedive total history
        lifetime
      • Depth notify
        yes (5)
      • Dive time alarm
      • Depth alarm
      • Surface time notify
      OUTDOOR FUNCTIONS
      WEATHER
      • Temperature
      • Temperature resolution
        1° C / 1.5° F
      • Temperature display range
        -20 to +50 °C/-4 to +122 °F
      • 5 stars: 12 (92%)
      • 4 stars: 1 (8%)
      • 3 stars: 0 (0%)
      • 2 stars: 0 (0%)
      • 1 star: 0 (0%)
      This product has no reviews of its own. The merchant grouped it with related products, so the reviews shown are from across that group.
      R
      Ryan Oestreich
      Easy and powerful
      Love the battery life, diving or wearing as everyday watch I have been impressed, sure beats my Apple Watch. Being at 3oz in weight also has been noticeably beneficial in my first week wearing it. Easy to use, just pick up and navigate easy!
      T
      Toebson
      Fun piece of Finnish Underwater Technology
      I got myself the lime version of the D5 and POD transmitter and I really like it. I am a scuba instructor trainer and freedive instructor and this computer allows me to benefit in both worlds with it. I had Suunto dive products for the last 16 years and that is my favorite so far. I used it on around 70 scuba dives in Indonesia, North Carolina and Mexico and on countless pool and open water freediving sessions until now.It took me a little while to customize it until I liked the settings that I would see underwater. I suggest to trim down the different displays to only see what you really need underwater otherwise you waste time scrolling through the menus underwater.The display: sometimes it appears to be hard to see at first on the surface. However in direct sunlight, on the surface and underwater it is crystal clear. The Memory in Pixel type display is very appealing and looks kind of futuristic to me.Battery life: after one charge I get 11h underwater time with "low screen brightness". If I am not underwater this charge will last probably 3-4 days. So I charge it just with my smart phone over night.In freedive mode I can feel the 15ft depth alarm vibrations through my 3mm suit, but not through my thicker suits. It gives me all I need during breathe-up and on the dive. Even an ascent and descent rate.The air integration: this feature is very useful as scuba diver and this new generation of Suunto POD work flawless. The paring was super quick and super stable for me.Accessories: I really like the different straps that Suunto offers. They are super easy to change, the silicone ones feel really good and the look stylish. I got the additional one Blue Nato and Black Silicone.Software: It has a great logbook with visualization of the dives and a very quick linking with the bluetooth app. However the app is still not 100% - I don't need a "daily goal" when I am scuba or freediving or I have not found yet how to turn that feature off in the app.I can totally recommend this product. Best price/value from Suunto since the Mosquito.And as a personal Suunto side note: Since the old Spyder and Stinger series I found the D-Series having lost a bit their character - with the exception of this new D5: that computer has character!
      A
      Amazon Customer
      I recommend
      Being in Brazil, I made this purchase with this seller and sent it to a hotel where a friend was staying and everything went well with the delivery, there was a setback but the seller kept me well informed of everything that was happening and then remade the delivery, super attentive. I recommend it to everyone
      A
      Anonymous
      Awesome dive
      Awesome dive watch
      J
      Jeff Sinon
      Exactly what I was looking for, almost.
      FWIW, this is a preliminary review based solely on the features, price-point, and reviews that prompted me to choose the D5 over other dive computers. The D5 offered everything I was looking for in a dive computer, including AI and a digital compass, at an excellent price for an AI wrist mount dive computer. I also really appreciate the simple 3 button layout. My one and only complaint so far is that if Suunto is going to sell this as a dive computer, it should come with a watch strap, and/or an extension strap so it can actually be worn over a wetsuit. Being forced to pay an additional $60 for the extension strap just to be able to use it is disappointing. That being said, I’m looking forward to getting this thing in the water.
      O
      Orlando calvo
      rechargeable battery battery blue two compass air integration
      Suunto d5 for me is the best dive watch that i ever had the color screen the blue two the air integration the compass for only mention a couple of the features make this a unique tool for dives that like to wear his computer as he every day watch
      M
      Malcovitch Malcovitch
      Very happy with this computer
      Here’s the basics:The screen is bright and easy to see.It’s easy to use for diving. Very simple yet feature packed - you can add integrated air!It syncs with an app on your phone for easy access to diving data. You can plot the temperature and everything.It can be a smart watch to receive text messages and notifications from your phone.It’s a great balance of size where it’s easy to push the buttons with gloves on, and it’s almost not too crazy to wear on your wrist as a watch.
      M
      Maria W
      Suunto D5 - worth every penny
      Easy to set up, read the screen underwater, link to laptop and it's rechargeable.
      J
      Jorge Cano
      Excelente producto
      Muy buen reloj, tiene todo lo necesario para un gran número de deportes
      G
      Gal Shtokhamer
      I love this watch
      I switched from my old SUUNTO D4i after it kept up eating batteries.I love this new model, no more batteries, you charge it with usb cable plus there is a clear indication of how many hours you have left on the battery.I use this watch for freediving, so the vibration mode helps so much, half the times I just don't notice the alarm beeping, but with the vibration its harder to miss.I also like the new display.and the fact that all my dives get synced to my phone after the dive so I can go through them after and analyze is amazing - a great buy!
      P
      Placeholder
      Quality
      I bought for my husband and he loves it!
      L
      Lia W
      A great dive computer!
      The product came exactly as described. This is a great dive computer for both recreational and tec diving. A bit expensive but a good purchase
      M
      Marco Salazar
      Easy to use and to understand
      I'm pretty new at diving but I wanted a computer that would give all the relevant information while I'm underwater and I have to say this is a great computer. I've used it on 5 dives so far and it's pretty easy to transfer your logs to the Suunto app via bluetooth.It has different views, so as soon as you touch the water it will show you the depth screen, where you can see how deep you're and your diving time. You have a third option to switch between your max depth, your time before deco, temperature and remaining battery.You can switch to your compass view, so it can help you navigate. It's easy to lock your bearing by holding a button. To unlock it you do need to navigate into the settings menu and you need to do it once you're out the water. Your compass needs to be calibrated after every time you charge your computer.I don't have the wireless transmitter so I didn't use the gas remaining screen.When you are ascending you see if you are ascending at a good pace or if you are ascending too fast, it you're too fast it will sound an alert and vibrate. It will also recommend you deep stops and safety stop. You can configure this at the settings.After you finish diving it will show you your no fly time and your surface time.The settings menu might be confusing at first but then it's pretty easy to navigate. When diving the light is always on, so consider it when setting the bright level.
      VIDEOS
      You can now create dive modes for the Suunto EON family and Suunto D5 in Suunto app.
      Learn how to set depth notifies and a surface notify to use Suunto D5 for advanced free diving.
      Learn how to pair your Suunto D5 with the Suunto app for Android and how to get started with the app.
      Learn how to pair your Suunto D5 with the Suunto app for iOS and how to get started with the app.
      Learn how to use the compass bearing of your Suunto D5.
      DM5 is Suunto’s desktop software to customize and update the firmware of your dive computer. DM5 offers various customization options for Suunto D5.
      SUPPORT FOR SUUNTO D5
