1 / 8
Suunto Cobra3 - SUUNTO US
1/8
SKU: SS014587000
Suunto Cobra3
Advanced air-integrated dive computer with electronic 3D compass
Suunto Cobra3
$9,999.99
Out of Stock
Suunto Cobra3 is an all-in-one console-mounted dive computer. It features air-integration, an electronic 3D compass, an easy-to-read matrix display, and simplified four-button operation.
Air integration
Suunto Cobra3 monitors and displays your tank pressure, tracks your rate of air consumption, and continuously calculates your remaining air time. It also provides visual and audible alarms for depth and pressure and warns you when you're running low on air.
Clear navigation
Suunto Cobra3 features a unique electronic 3D compass that can be tilted up to 45 degrees in any direction, making it easier to read the figures clearly and accurately under water.
Effortless operation
The easy-to-read dot matrix display and electro-luminescent backlight mean all your dive-critical information – including bearing, tank pressure, depth, and dive time – will all be shown clearly. And with the simplified four-button operation, the computer is easy to operate even when wearing gloves.
Multi-mode versatility
With its Nitrox, Air, and Gauge modes and gas-switching capabilities, Suunto Cobra3 delivers everything you need to maximize bottom time and make the most of every dive. When using enriched air, Suunto Cobra3 can be programmed for nitrox mixtures between 21% and 100% oxygen. You can also adjust oxygen partial pressure between 0.5 and 1.6 bar. In Gauge mode, it can also be used as a depth gauge and timer with profile memory.
Flexible decompression
Using the Suunto Deep Stop RGBM algorithm, Suunto Cobra3 enables continuous decompression for optimal ascent time. For deeper dives, the Deep Stop option adds further protection with a series of deep stops between your maximum depth and ceiling. When in Nitrox mode, you can accelerate decompression by switching to a gas mix with a higher oxygen percentage. With Suunto Cobra3 it's quick and easy to switch between enabled gas mixes while diving.
Plan and review
You can test upcoming dives and view no-decompression and decompression time data for different depths before getting in the water with the built-in dive simulator. When the dive is over, get detailed graphical logs and dive data on your computer using Suunto DM4 software.
PRODUCT HIGHLIGHTS
  • Air, nitrox, and gauge modes
  • 3D compass
  • Suunto RGBM
  • Easy-to-read matrix display
Specifications
  • Measurements
    73 x 165 x 35 mm / 2.87 x 6.5 x 1.38 "
  • Weight
    210 g / 7.41 oz
  • Bezel material:
    Composite
  • Glass material:
    Acrylic
  • Case material:
    Composite
  • Strap material:
    Elastomer
  • Country of manufacture
    FI
  • Air integrated for tank pressure information
  • Tiltable electronic 3D compass to keep you on course
  • User-friendly design featuring easy-to-read matrix display and simplified four-button operation
  • Three dive modes and gas-switching capability for a range of dive situations
  • Continuous decompression with the Suunto RGBM algorithm
  • Built-in dive simulator for planning upcoming dives
  • Optional computer interface for detailed graphical logbooks and dive data analysis
Technical specifications
  • Bezel material:
    Composite
  • Glass material:
    Acrylic
  • Case material:
    Composite
  • Strap material:
    Elastomer
  • Declination correction
    yes
  • Weight
    210 g / 7.41 oz
  • Water resistance
    100 m (ISO 13319)
  • Battery life 100 dives/year
    1.5 years
  • Battery type
  • User replaceable battery
  • Time, date
  • Alarm clock
    1 daily alarm
  • Languages
    EN
  • Backlight
    electro-luminescent
  • Configurable backlight
    duration: 5, 10, 20, 30, 60 s
  • Display type
    matrix
  • Display resolution
    49 x 22
  • Battery indicator
    low battery indicator
  • Metric and imperial units
BATTERY LIFE
  • In time mode
    3 years
CONNECTIVITY
  • Data transfer
    USB cable (optional)
  • Compatible with DM5
COMPASS
  • Digital compass
  • Tilt compensation
    up to 45°
  • Direction scale
    degrees
  • Needle
    compass rose
  • Globally balanced
  • Compass accuracy
    10°
  • Compass resolution
    1°
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
DIVING FUNCTIONS
BASIC
  • Nitrox (and air)
  • Gauge
  • Dive time
    0 to 999 min
  • Surface time
    0 to 99 h 59 min
  • No fly time
  • Safety Stop
  • Deep Stop
  • Ascent time display
    0 - 99 min (- - after 99)
  • CNS/OTU (OLF) calculation
  • Hose air integration
  • Decompression model
    Suunto RGBM
  • Personal adjustment
    0 - 2
  • Altitude adjustment
  • Gases
    up to 2 gases (Oxygen 21 - 99%)
  • Gas max pO2
    1.2 - 1.6
  • Gas switching
  • No-decompression planner
  • Logbook memory
    ~42 h (20 s sampling rate)
  • Logbook bookmarks
  • Logbook sampling rates
    1, 10, 20, 30, 60 s
  • Dive history
    lifetime
DIVE ALARMS AND NOTIFICATIONS
  • Dive time
  • Maximum depth
  • Tank pressure
  • High pO2 (hyperoxic)
  • Too fast ascent
  • CNS/OTU (OLF) 80% / 100%
OUTDOOR FUNCTIONS
WEATHER
  • Temperature display range
  • Temperature resolution
    1° C / 1.5° F
  • Temperature
SUPPORT FOR SUUNTO COBRA3
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto dive computer.
