1 / 8
Suunto Ambit3 Peak Black - SUUNTO US
1/8
Money-back guarantee
30-Days Return
Global Support
SKU: SS020677000
The GPS outdoor watch with route altitude profile navigation and extremely long battery life
30-Days Return
Global Support
$0
Out of Stock
CLASSIC ADVENTURE COMPANION
Whether you’re reaching for the top of the summit or a new personal best, Suunto Ambit3 Peak will be there to help you. A GPS watch designed for adventures that reach the edges of the map, it provides everything you need to find your way, stay safe and follow your progress.
KEY FEATURES
LONG BATTERY LIFE
GPS navigation
BAROMETER FOR ALTITUDE ACCURACY
WEATHER FUNCTIONS
100 M WATER RESISTANT
10 SPORT MODES
DIGITAL COMPASS
SUNRISE AND SUNSET TIMES
This thing has proven itself to be of incredibly high quality.
All Day Ruckoff
"The Suunto Ambit3 Peak represents the latest in wearable technology"
Gear Institute
"The battery life on the Ambit3 Peak is also simply outstanding."
Phil the Runner
BENEFITS
Right tools for the outdoors
Accurate altitude measurements are delivered by FusedAlti, which combines GPS with barometric altitude. The barometric trend predicts changes in weather and the storm alarm lets you know when it’s time to find shelter. Sunrise and sunset times keep you informed of remaining daylight hours.
Adventure-proof
Looking to go off the grid or on a longer journey? Suunto Ambit3 Peak comes with up to 200 hours of battery life with the GPS turned on that lets you explore longer. Designed for durability, you can rely on it on your treks off the beaten path. It’s also water resistant up to 100 meters.
Read more about Suunto app
Sports tracking essentials
Keep track of your exercises, progress and recovery with ten customizable sport modes and detailed information on your exercises. You can also connect your watch to Suunto app and view your exercises there or take advantage of Suunto’s wide network of partners to access more features and training tools.
Specifications
  • Measurements
    50 x 50 x 18 mm / 1.97 x 1.97 x 0.71 "
  • Weight
    89 g / 3.14 oz
  • Bezel material:
    Steel
  • Glass material:
    Mineral crystal
  • Case material:
    Polyamide
  • Strap material:
    Elastomer
  • What's in the box?
    Suunto Ambit3 Peak Black, USB cable, Quick Guide, Warranty Leaflet
  • Country of manufacture
    FI
Technical specifications
  • Bezel material:
    Steel
  • Glass material:
    Mineral crystal
  • Case material:
    Polyamide
  • Strap material:
    Elastomer
  • Weight
    89 g / 3.14 oz
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Automatic timekeeping
  • Countdown timer
  • Stopwatch timer
  • Languages
  • Backlight
    LED
  • Configurable backlight
    brightness / mode
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Battery indicator
    percentage / icon
  • Metric and imperial units
  • Autoscrolling of exercise displays
  • Memory left indicator
BATTERY LIFE
  • In time mode
    30 days
  • Training mode with GPS
    20, 30, 200 h For more information www.suunto.com/software-updates
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    5
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Create own metrics with advanced formulas
  • Chrono, GPS, HR, weather and altitude data
  • Running, cycling, swimming data
  • Rich math functions, if/then-logic, sound, backlight, etc.
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
    5°
  • Compass resolution
    1°
  • Declination correction
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
CONNECTIVITY
  • Watch customization
    USB cable
  • Data transfer
    Wireless / USB cable
    Bluetooth Smart
  • Smartphone compatibility
    iPhone, Android
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS
  • GPS recording rate
    1, 5, 60 s
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Find back
    in Suunto App
  • Route planning
    in Suunto Movescount.com
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
  • Route altitude profile navigation in real-time
  • Track back
    yes
ALTIMETER
  • Barometric altitude
  • GPS altitude
  • Altitude graph
  • Total ascent/descent
    air pressure based
  • Vertical speed
    air pressure based
  • Altitude difference
    yes** ** available as Suunto Apps
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
  • Automatic alti/baro profile
WEATHER
  • Sea level pressure
  • Sea level pressure graph
  • Weather trend indicator
  • Temperature
  • Temperature display range
  • Sunrise/sunset times
  • Storm alarm
  • Tide information
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Temperature resolution
    1°
  • Max weather recording length
    past 26 hours
TRAINING FUNCTIONS
SPEED AND DISTANCE
  • Distance based autolaps
    1, 10 s
  • Chrono
  • Laps
    > 1000
  • Autopause
  • GPS speed and distance
    Integrated
  • Foot POD support
    Bluetooth Smart
  • Bike POD support
    Bluetooth Smart
HEART RATE
  • RR interval
  • Heart rate in % of max hr
  • Real-time average and max heart rate
  • Heart rate limits
  • Calories
  • Peak Training Effect
  • Recovery time
  • Real time EPOC
    1, 10 s
  • Speed and heart rate-based guidance during exercise
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
TRAINING RECOVERY
  • Sleep recovery test (Firstbeat™) For availability information check www.suunto.com/software-updates
  • Quick recovery test (Firstbeat™)
SPORT EXPERTISE
SPORT MODES
    10 modes / 8 displays per mode
MULTISPORTS
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Average pace in real time
  • Running cadence
    watch or Foot POD
  • Average stride length
  • Marathon End-time Estimator
  • Lap comparisons by kilometer/mile
  • Running Performance (Firstbeat™) For availability information check www.suunto.com/software-updates
  • Running power
    with Stryd sensor
  • Foot POD calibration
    manual or GPS
CYCLING
  • Cycling speed
  • Average speed in real time
  • Multiple Bike POD support
  • Hill incline in real time
    yes, available as Suunto Apps
    Bluetooth Smart
  • Bike Power 3s, 10s, 30s (with power sensor)
  • Normalized Power (Suunto Apps / TM by Training Peaks)
  • Aerodynamic drag in real time (with power sensor)
  • Cadence POD Support
    Bluetooth Smart
SWIMMING
  • Pool swim pace and distance
  • Openwater swim pace and distance
  • Swim styles detection with personal style teaching
  • Stroke efficiency (SWOLF)
  • Automatic intervals
    Yes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Recommended products
Support for Suunto Ambit3 Peak
