Out of Stock
1 / 7
Karoo 2 Cycling Computer - SUUNTO US
1/7
Money-back guarantee
30-Days Return
Global Support
SKU: SS050800000
$399
Suunto compatible cycling computer that brings the power of advanced navigation, Suunto heatmaps, and intuitive software to your handlebars, all on a stunning, smartphone-like display.
Quantity
$399
Out of Stock
Compare +
30-Days Return
Global Support
$399
Out of Stock
See the adventure ahead
Karoo 2 is a Suunto compatible cycling computer that brings the power of advanced navigation and intuitive software to your handlebars, all on a stunning, smartphone-like display. When connected with Suunto app, Suunto heatmaps show the most popular rides right on Karoo 2 screen. With Suunto app you can create new routes for your Karoo 2 even on the go.
Afterwards all your rides are available for further analyses in Suunto app – along with the runs, swims, strength sessions and other exercise you have tracked with your Suunto watch. The long-term analyses in Suunto app are powered by TrainingPeaks. Suunto app also helps you monitor your daily activity and sleep to keep your life in balance.
“The Hammerhead Karoo 2 is the best GPS cycling computer you’re not using.”
Bicycling
“The screen is simply the best on the market, with incredible resolution, and also smartphone-like touchscreen responsiveness.”
The Independent
“The overall navigation and display experience is unlike anything else out there.”
DC Rainmaker
“The best screen and navigational metrics in the game.”
Cycling News
Suunto heatmaps to go
When connected with Suunto app, Suunto heatmaps show the most popular rides right on Karoo 2 screen. Suunto app also enables you to create routes.
Reliability is Karoo 2's bedrock
Reliability is Karoo 2’s bedrock principle, so that your equipment never gets in your way. Karoo also has industry’s leading customer support should you ever need it.
Continuous enhancement
Regular software updates introduce new features and enhancements to Karoo 2. They keep Karoo 2 at the cutting edge of the cycling ecosystem.
Stunning screen
Karoo 2 has the largest color spectrum and twice the pixel density (292PPI) of its closest rival, all on a smartphone-like responsive touchscreen.
Next Gen software
Intuitive software delivers a seamless Strava Live Segments experience, the best mapping and navigation, detailed upcoming elevation, and highly accurate data, allowing you to explore and achieve your goals.
All your training data in Suunto app
All your rides and other data in Suunto app for analyses – long term powered by TrainingPeaks
BENEFITS
Software
Predictive Path Technology See upcoming curves and climb profiles without uploading a route. 
See what matters most A highly customizable display so you always get the data you need.
Cloud syncing All routes automatically sync and are ready to go. Pick and choose depending on your ride.
Navigation that works every time Instant, detailed turn-by-turn directions for anywhere in the world. Fast rerouting keeps you on track even if you miss your turn.
Conquer the cols Detailed upcoming elevation profiles for every ride, even without a route uploaded.
Strava Live SegmentsSet new personal bests using beautiful Strava Live Segments.
External hardware
See your data as never before
A screen that’s ready for any adventure
Ride in rain or shine with anti-glare texturing and droplet rejection. The Dragontrail™ Glass screen can take whatever your ride throws at it. 
Intuitive control over your entire ride experience
Four buttons give you full control when you don’t want to use the touchsceen. An elastomer edge protects your device from impact.
Big power, small package
40% smaller and 33% lighter than the original Karoo, with supreme performance from its quad-core processor.
Plug into the future
Karoo 2 leads the industry with the latest in waterproof USB-C technology for fast charging.
Internal hardware
Total connectivity
Two low energy chipsets connect to Bluetooth, Smartphone, ANT+, Wifi, 3G, 4G and GPS. Karoo 2 is the most connected head unit available.
All the space you need
32GB of high-speed storage gives you plenty of room for maps, data and software.
Measure everything 
High-accuracy thermometer, 3-axis accelerometer, magnetometer, and gyroscope give you the full picture of your ride.
Listen up
Powerful audio alerts delivered by Karoo 2’s beeper or over bluetooth audio.
Charge faster 
Fast charging gets Karoo 2 to 30% in 30 minutes and 50% in 1 hour. 
Specifications
  • Measurements
    60.8 x 100.6 x 19.3 mm / 2.39 x 3.96 x 0.76 "
  • Weight
    131 g / 4.62 oz
  • Glass material:
    Dragontrail™ with anti-glare etching
  • Case material:
    Glass-filled high-impact polycarbonate chassis with interlocking protective shells and weather-resistant gaskets
  • What's in the box?
    Hammerhead Karoo 2, Hammerhead Mounting System, Quarter-turn Mounting Adapter, 2.5mm allen key, USB-A to USB-C Cable, Lanyard, Getting Started Guide
Technical specifications
PHYSICAL SPECIFICATIONS
  • Operating temperature
    -15° C to +55° C / +5° F to +130° F
  • Storage temperature
  • Glass material:
  • Case material:
  • Weight
    131 g / 4.62 oz
  • Touch screen lock
  • Touch display
  • Color display
  • Battery indicator
    percentage / icon
  • Firmware upgradable
  • Time, date
  • Languages
    English only
  • Backlight
    user-adjustable
  • Display size
    3.2" diagonal
  • Display type
    TFT LCD
  • Display resolution
    480 x 800
  • Metric and imperial units
  • Battery type
    rechargeable lithium-ion
  • Water resistance
    IP67
  • Customized displays in device
  • Internal storage
    32 GB
CONNECTIVITY
  • Compatible with Suunto app
  • Smartphone compatibility
    Most common models supported
  • WiFi
  • ANT+
  • Bluetooth
    Sensor and audio
  • Mobile network (via optional SIM card)
    2G/3G/4G
  • Phone notifications
  • Software updates from cloud
    Over-the-air via WiFi
  • USB-C
  • Live tracking
ONBOARD SENSORS
  • 3-axis accelerometer
  • 3-axis magnetometer
  • 3-axis gyroscope
  • Altimeter
  • Temperature
BATTERY LIFE
  • Battery life
    12 hours of ride time
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS, GLONASS, QZSS, BEIDOU
  • GPS recording rate
    1s
  • Zoom levels in navigation
    via Suunto app & Hammerhead.io
  • GPS track analysis
    via Dashboard
  • Pin-drop route creation
  • Routing customization
  • Rerouting speed
    under 5 seconds
  • Auto-detect upcoming climbs
  • Offline navigation to route start
  • Personal route library synced to Karoo 2
  • Wireless route import
  • Auto route sync
  • Map on device
  • Beeper notification for navigation
  • Historic elevation graphs
  • Upcoming elevation graphs
ALTIMETER
  • Barometric altitude
  • GPS altitude
  • Vertical speed
  • Automatic alti/baro profile
  • Log recording rate
    1 s
  • Resolution
    1 m
  • Range
    -500 - 9000 m
TRAINING FUNCTIONS
HEART RATE
  • Personal heart rate zones
  • Heart rate sensor compatibility
SPEED AND DISTANCE
  • GPS speed and distance
  • Autolaps
  • Chrono
    via GPS/Speed Sensor
  • Manual laps
    via 3rd parties such as Strava
SPORT EXPERTISE
CYCLING
  • Cycling speed
  • Average speed in real time
  • Bike lap and Lap Maximum Power
  • Bike power (W), average and maximum
  • Electronic shifting
    with SRAM eTap, SRAM AXS, Shimano Di2, Campagnolo EPS and FSA K-Force
  • Rearview radar
    with ANT+ radar devices
SPORT MODES
  • Suitable for sports
    cycling, indoor cycling, mountain biking
Recommended products
Support for Hammerhead Karoo 2
Find the full user guide, how to videos and detailed support information for your Karoo 2 at hammerhead.io.
