When navigating with a map and a compass, it is important to understand that the true or geographical north (North Pole) is not the same as magnetic north. The angle between true north and magnetic north is called declination and is either east or west of magnetic north depending on where you are on Earth.
East declination means that locally the Earth’s magnetic field points in a direction that will pass the North Pole on the east side. West declination passes on the west side. In many parts of the world declination is so small that you do not need to take it into consideration in practical outdoor navigation. However, in some places around the declination is significant and must be accounted for at all times in order to navigate accurately.
You should always check your local declination from a trusted source before you start navigating. The declination angle changes over time due to the fluctuation of Earth’s magnetic field.
Many Suunto compasses provide either fixed or adjustable declination correction. The fixed declination correction is an additional scale under the compass needle. This is used by first taking the direction with the protractor and then turning until the compass needle points at the declination scales according to the local declination. This must be done every time the compass is read.
Adjustable declination correction is set once when starting to navigate by turning the North arrow in the bottom of the capsule to the angle that corresponds with your local declination. The compasses are equipped with a small screwdriver and a printed declination scale to assist in making this adjustment.
After setting the declination correction, the compass can be used without having to account for the declination until you move to a new location with a different declination.
There is a third North called map north. The map may show a difference in the direction towards true north depending on if you are on the middle meridian of the map or at the east or west edge of the map. If this is the case, the printed map will have a description of this perspective error together with the declination information. In outdoor navigation, landmarks are usually appearing so often that this effect can be ignored.
In addition to declination, other phenomena can affect the direction a compass points. The ground may contain magnetic minerals, like magnetite, that can have a big impact on the compass. It is important to regularly check your progress on the map while moving to be able to correct for variations causes by such minerals.
Power lines and other human constructions may also impact a compass reading. Crossing bridges or underground pipes, even working on a surface with nails can cause temporary changes in the compass reading. Magnetic materials or items you are carrying can affect your compass reading as well.
Always be aware of what is with you and around when using a compass. Distance yourself from possible disruptions to get a good reading.
Your subheading
Your title
Suunto AI Coach — The coach you always wanted
Suunto AI Coach  ·  New
The coach you
always wanted.
You already know what you did yesterday. Suunto AI Coach helps you decide what to do tomorrow.
Know what to
train
Plans that adapt to your goals and the time you have.
Know where to
go
Routes matched to your fitness and where you are.
Know when to
recover
Readiness from your recovery, sleep and training load.
Key benefits
More than a training plan.
It analyses your training, adapts your plan, guides your recovery and helps you find where to go next.
Builds training around you
Creates and adapts training based on your fitness, goals and available time.
Knows when to push or recover
Analyses your training load, recovery, sleep and activity history before recommending what to do next.
Creates routes for your watch
Ask for a route and it builds one around where you are, then sends it to your watch to navigate.
Answers your questions
Ask naturally about your training, recovery or routes and get answers based on your own data.
Adapts with every activity
Each workout, adventure and recovery period helps your coach better understand what you need.
See it in action
Ask your coach,
almost anything.
Plan a workout, build a route, compare your months or check a trend, all from your own data, right in the Suunto app.
Suunto AI Coach
Your app and watch, as one.
The app does the thinking, your watch gets you moving, and Suunto AI Coach keeps the two in step.
01
Ask, wherever you are
“Find me a local 7k route” or “what should I train today?” On holiday or at home, just ask.
02
AI Coach works it out
It draws on your goals, your training and where you are, for a real answer, not generic advice.
03
Get it where you need it
A route, workout or plan syncs to your watch. An answer or insight stays in the app.
How to get it
Two ways in.
Get a Race 3 series watch
Three months included
Race 3 S and Race 3 come with three months of Suunto AI Coach, whether you’re new to Suunto or upgrading.
Explore the watches
Use your current Suunto
Apply for early access
Already have a compatible Suunto watch? Join the Pioneers Program and try Suunto AI Coach before wider availability.
Supported devices
Get Suunto AI Coach with the Race 3 series.
A Race 3 series watch is the fastest way in, with three months of Suunto AI Coach included.
Suunto Race 3 S
3 months included
Race 3 S
Available first
Lightweight trail performance. 1.32″ AMOLED, dual-band GPS, sapphire crystal.
Explore Race 3 S
Suunto Race 3
3 months included
Race 3
Coming later in 2026
Bigger 1.5″ AMOLED display and longer battery for the long days out.
Explore Race 3
How to activate
Up and running in minutes.
Got a Race 3 series watch? Start your three months of Suunto AI Coach in a few steps.
01
Open the Suunto app
Download or open it, and sign in to your Suunto account.
02
Register your watch
Add your Race 3 series watch and your three-month trial activates automatically.
03
Ask your first question
AI Coach is ready in the app. Ask what to train, or plan a route.
Pricing
Three months included. Continue when you choose.
Your Race 3 series watch includes three months of Suunto AI Coach. Continue with a paid plan after your trial to keep your coaching active.
Explore the Race 3 series
Pioneers Program
Already a Suunto user? Get in early.
Apply to join the Pioneers Program and experience Suunto AI Coach before wider availability. Existing owners with compatible watches come first.
Sign in with your Suunto account
We’ll use your account to confirm your watch and email, nothing to type.
Spots available · limited intake
No Suunto account? Apply with your email
Thanks. You’re on the list, we’ll be in touch.
FAQ
Good to know.
What is Suunto AI Coach?
Suunto AI Coach turns your training, recovery and route data into guidance you can act on. Ask what to train, when to recover, or where to run, and get answers based on your own activity, right in the Suunto app.
How is this different from Suunto Coach?
Suunto Coach builds your structured training plan. Suunto AI Coach is the coach you can talk to: ask questions in your own words and get adaptive guidance across training, recovery and routes, in the moment and from your own data.
Which watches work with it?
At launch, Suunto AI Coach comes with the Race 3 series, Race 3 S and Race 3, with three months included. Owners of other compatible Suunto watches can request early access through the Pioneers Program.
What does it cost?
It is free for three months with a Race 3 series watch. After the trial it continues as a paid plan, planned for 2027. Join the Pioneers Program and we’ll share plan details before launch.
What can I ask it?
Plenty. Plan a workout for today, build a running route, compare this month with last, check a trend like your resting heart rate, or ask whether you’re ready to push. If it relates to your training, recovery or adventures, ask away.
How do I activate it?
Get a Race 3 series watch, open the Suunto app and register it. Your three-month trial activates automatically, so you can start asking straight away.
What data does it use?
Suunto AI Coach works from your own Suunto data, your training, recovery, sleep and routes, to make its guidance personal rather than generic.
What technology is behind Suunto AI Coach?
Suunto AI Coach is built by Suunto and runs inside the Suunto app. It combines your own training, recovery and route data with Suunto’s sports science, so the guidance is personal and relevant rather than generic.
Can I connect my own AI, like ChatGPT?
Suunto AI Coach is designed to work natively with your Suunto data, so you get connected, reliable guidance without handing your training data to outside tools. The focus is a seamless in-app experience rather than plugging in external chatbots.
