Import
To import dive logs to DM5, open File > Import. You can import the following file formats: SDE, XML, SDP and SML.
Export
To export dive logs from DM5, open File > Export. You can choose from five file formats:
  • PDF: Dive data for selected dives will be saved in one file.
  • SDE: Dive data for selected dives will be saved in one file.
  • XML: Dive data of individual dives will be saved in separate files.
  • SML: Dive data of individual dives will be saved in separate files.
  • DAN DL7: Choose this file format, if you want to donate your dive logs to the DAN research project. Learn more here.
Note: If you move from an older version of Dive Manager to a newer (DM4 or DM5), use the Export functionality. Export your dive logs in SDE, XML or SML file format and import them to your new version of Dive Manager.
Subheading
Image with text
Use image with text to give your customers insight into your brand. Select imagery and text that relates to your style and story.
