1 / 7
Suunto Traverse Alpha Concrete
1/7
Money-back guarantee
30-Days Return
Global Support
SKU: SS023446000
GPS/GLONASS watch with versatile outdoor functions for fishing and hunting
30-Days Return
Global Support
Go explore
Suunto Traverse Alpha combines strong build quality with a full set of outdoor features. It is your guide in the wild, keeping you on track with GPS/GLONASS navigation. Specific fishing and hunting features provide useful tools for your activity, including moon phase calendar, shot detection, sunrise alert, weather trend, and red backlight for nighttime use. Plan your routes and keep a diary of your fishing and hunting trips with Suunto Movescount.The strap pattern in Traverse Alpha Concrete draws inspiration from the camouflage pattern used by the Finnish military.
PRODUCT HIGHLIGHTS
  • Master your territory with GPS/GLONASS navigation
  • Dedicated functions for fishing, hunting and hiking
  • Made in Finland, tested to military standards
Specifications
  • Measurements
    50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
  • Weight
    75 g / 2.65 oz
  • Bezel material:
    Stainless steel
  • Glass material:
    Sapphire crystal
  • Case material:
    Composite
  • Strap material:
    Textile
  • What's in the box?
    Suunto Traverse Alpha Concrete, USB cable, quick guide, warranty leaflet
  • Country of manufacture
    FI
  • Hiking, Fishing and Hunting modes
  • Sunrise-sunset times and alerts
  • Fishing and hunting specific POI types
  • Moon phases and moon rise/set times
  • Red backlight, Night Vision Goggle compatible
  • GPS and GLONASS for route and POI navigation
  • Real-time breadcrumb view of the recorded track
  • Tracking for speed, distance and altitude
  • Discover new routes with heatmaps on Suunto app
  • Route preview and route altitude profile on the watch
  • 100 m/330 ft water resistance
  • Altitude (FusedAlti™)
  • Weather trend and storm alarm
  • Compass
  • Backlight in flashlight mode
  • Vibration alarm
  • GPS time update
  • Daily, weekly, monthly and yearly activity tracking of steps and calories
  • Mobile notifications
  • Compatible with Suunto app (iOS and Android)
Accuracy of data monitoring
Automatic shot detection
Technical specifications
  • Bezel material:
    Stainless steel
  • Glass material:
    Sapphire crystal
  • Case material:
    Composite
  • Strap material:
    Textile
  • Weight
    75 g / 2.65 oz
  • Water resistance
    100 m
  • Battery type
    rechargeable lithium-ion
  • Firmware upgradable
  • Time, date
  • Alarm clock
    1 daily alarm
  • Dual time
  • Countdown timer
  • Stopwatch timer
  • Vibration alert
  • Languages
  • Backlight
    LED
  • Configurable backlight
    color / brightness / mode
  • Flashlight backlight option
  • Button lock
    customizable
  • Invert display
  • Display type
    matrix
  • Display resolution
    128 x 128
  • Battery indicator
    percentage / icon
  • Metric and imperial units
  • Memory left indicator
  • Automatic timekeeping
BATTERY LIFE
  • In time mode
    14 days
  • Training mode with GPS
    10, 15, 100 h For more information www.suunto.com/software-updates
CONNECTIVITY
  • Smartphone compatibility
    Most common models supported
  • Data transfer
    Wireless / USB cable
  • Watch customization
    USB cable
    Bluetooth Smart
    with Suunto App
    Strava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
SUUNTO APPS
  • Compatible with Suunto Apps
  • Max. nr. of apps per sport mode
    4
  • Logging of app specific metrics
  • Most recommended apps by activity
  • Chrono, GPS, HR, weather and altitude data
  • Rich math functions, if/then-logic, sound, backlight, etc.
  • Create own metrics with advanced formulas
COMPASS
  • Digital compass
  • Tilt compensation
    full
  • Declination correction
  • Direction scale
    degrees / mils
  • Needle
    north indicator
  • Compass accuracy
  • Compass resolution
PHYSICAL SPECIFICATIONS
  • Operating temperature
  • Storage temperature
24/7
ACTIVITY TRACKING
  • Step counter
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
  • Satellite systems
    GPS, GLONASS
  • GPS recording rate
    Best, Good, OK
  • Coordinate systems
    WGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
  • Max. nr. of Points of Interest (POIs)
    250
  • Find back
    in Suunto App
    in Suunto Movescount.com
  • Route altitude profile navigation in real-time
  • Route points per route / POIs in watch
    1000 / 250
  • GPS track analysis
    in Suunto App
  • Track back
    yes, incorporated with breadcrumb trail
  • Route planning
ALTIMETER
  • Barometric altitude
  • GPS altitude
  • Altitude graph
  • Total ascent/descent
    air pressure based
  • Vertical speed
    air pressure based
  • Automatic alti/baro profile
  • Altitude difference
    in log summary, and real time as an App
  • Log recording rate
    1, 10 s
  • Resolution
    1 m
  • Range
    -500 - 9999 m
WEATHER
  • Sea level pressure
  • Sea level pressure graph
  • Weather trend indicator
  • Temperature
  • Temperature display range
    -20° C to +60° C / -4° F to +140° F
  • Sunrise/sunset times
  • Moon phase calendar
  • Storm alarm
  • Tide information
    yes** ** available as Suunto Apps
  • Pressure resolution
    1 hPa / 0.03 inHg
  • Temperature resolution
  • Max weather recording length
    past 26 hours
TRAINING FUNCTIONS
SPEED AND DISTANCE
  • GPS speed and distance
    Integrated
  • Distance based autolaps
    1, 10 s
  • Chrono
  • Laps
    > 1000
  • Autopause
HEART RATE
  • Heart rate in % of max hr
  • Calories
    1, 10 s
TRAINING LOAD
  • Log summary on the watch with lap details
  • Training analysis
    in Suunto App
  • Training logbook with story and image support
    in Suunto App
SPORT EXPERTISE
SPORT MODES
    5 modes / 4 displays per mode
RUNNING
  • Running pace
  • Suunto FusedSpeed™
  • Average pace in real time
  • Lap comparisons by kilometer/mile
CYCLING
  • Cycling speed
    based on GPS
  • Average speed in real time
    based on GPS
HUNTING
  • Automatic shot detection Accuracy of data monitoring
  • Hunting specific POI types
  • Moonrise / moonset alert
  • Moonrise and moonset times for selected date
  • Red backlight, compatible with night vision goggles
  • Sunrise / sunset alert
FISHING
  • Fishing specific POI types
  • Storm alarm
  • Temperature
Recommended products
Videos
How to display the moon phase calendar on your Suunto Traverse Alpha, a GPS watch purpose-built for hunting and fishing.
How to change time and date settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change unit settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change vibration settings on Suunto Traverse and Traverse Alpha GPS watches.
How to change language on Suunto Traverse and Suunto Traverse Alpha GPS watches.
Suunto Traverse's display views.
How to change display contrast on Suunto Traverse and Traverse Alpha GPS watches.
First time start up with Suunto Traverse.
SUPPORT FOR SUUNTO TRAVERSE ALPHA
Find how to videos, FAQs, tutorial articles and detailed support information for your Suunto watch.
