1 / 10
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
SUUNTO MC-2
/G/6400 - SUUNTO US
1/10
Money-back guarantee
30-Days Return
Global Support
SKU: SS016326000
Suunto MC-2
/G/6400
$95
A professional mirror compass with top-of-the-line features for direction and slope measurements for mountain adventures.
  • Fast globally balanced needle with jewel bearing
  • Mirror for sighting bearings and signaling, with magnifying lens
  • Adjustable declination correction
  • USGS UTM scales
  • Clinometer
  • Luminescent markings for working in low light
  • Detachable snap-lock lanyard with wristlock
    Choose Your Color
    Quantity
    $95
    Compare +
    30-Days Return
    Global Support
    SUUNTO MC-2 /G/6400
    $95
    Add to cart
    Designed in Finland
    Made in Finland
    Limited lifetime warranty
    Exceptionally stable & fast needle
    Baseplate with magnifying lens
    Luminescent markings for low light
    Sighting compass for mountain adventures
    Integrated clinometer
    The clinometer is useful in uneven terrain where you need to determine slope gradient to pinpoint your exact location. It also helps to measure altitude.
    The lanyard with wristlock is easy to detach for working with the map.
    Made in Finland
    All Suunto compasses are handcrafted at our factory with 100% renewable energy.
    The compass liquid used by Suunto is specially formulated to provide damping over a large temperature range while preventing the needle from sticking.
    Stable operation
    Mirror for more
    The mirror on a compass serves the dual purpose of allowing you to sight bearings accurately and facilitating signaling by reflecting sunlight.
    Accurate bearings
    Sighting hole and notch in a compass facilitate precise navigation by allowing you to align the compass with distant landmarks and obtain accurate bearings.
    Specifications
    • Measurements
      65 x 101 x 18 mm / 2.56 x 3.98 x 0.71 "
    • Weight
      75 g / 2.65 oz
    • Bezel material:
      Plastic
    • What's in the box?
      Suunto MC-2/G/6400, lanyard with wristlock and declination correction tool, Quickrelease, Quick Guide
    • Country of manufacture
      FI
    • Direction in mils
    • 20 degrees tilt margin for easier readings
    • Liquid filled capsule for stable operation
    • Sighting hole and notch for accurate bearings
    • Clinometer
    • USGS UTM scales
    • Baseplate with magnifying lens
    • Detachable snap-lock lanyard with wristlock. Easy to detach for working with the map
    • Suunto limited lifetime warranty
    • Made in Finland
    • NSN: 6695-58-000-8341, 6605-21-920-8095
    Technical specifications
    • Bezel material:
      Plastic
    • Metric scales
      cm, 1:25 000 km UTM, 1:50 000 km UTM
    • Imperial scales
      inch
    • Declination correction
      adjustable
    • Weight
      75 g / 2.65 oz
    • Water resistance
      insensitive to water pressure
    • Battery type
      no battery required
    • Luminous markings
      orienting markings, direction of travel
    • Lanyard quick release
    • Attachment
      lanyard
    COMPASS
    • Direction scale
      mils
    • Needle
      Suunto global needle
    • Globally balanced
    • Liquid filled and jewel bearing
    • Compass accuracy
      2°
    • Compass resolution
      2°
    OUTDOOR FUNCTIONS
    GPS TRACKING & NAVIGATION
    • Sighting
      mirror, notch and hole
    • Mirror
    • Magnifying lens
    CLINOMETER
    • Clinometer
    • Clinometer scales
      0 ± 90°
    • Liquid filled
    • Inlcination accuracy
      2°
    • Inclination resolution
      2°
    • 5 stars: 47 (92%)
    • 4 stars: 4 (8%)
    • 3 stars: 0 (0%)
    • 2 stars: 0 (0%)
    • 1 star: 0 (0%)
    This product has no reviews of its own. The merchant grouped it with related products, so the reviews shown are from across that group.
    H
    Helping HanD
    Marine Opinion: Amazing Compass!
    Wish I bought one of these sooner! These are great for camping/hiking/emergency/survival!Love the extra features it comes with: Rulers for different scaled maps 1:50000 & 1:24000, ruler for 1:24000 maps that measures how many miles the distance is up to 1.1 miles, and a ruler in INCHES 3.5in, on the cover of the compass' sides there are declination angle marks, and of course the signal mirror is a great addition for emergency signalling or if you have some stuff stuck in your teethI flashed the compass with my surefire and the glow was visible in daytime for a short duration and works great at night time!I dont think its as rugged as a lensatic compass but luckily I only have to worry about 1 Marine possibly breaking this
    D
    DRESSLB
    Awesome Compass
    I got the global needle that compensates for the difference in the magnetic field world wide. The lid was a little tight and I shaved the plastic on the lid part and now it is perfect. Definitely a keeper!
    V
    Vaajhmoob
    What is the most important to know before you buy to get the correct one and how to use it
    For example Amazon.com1. They advertise as Suunto MC-2 But this Suunto MC-2 has many models with different CONFIGURATIONS and STYLEs and each one has its own part number, you have to high light the one you select to get the right part number and price to buy. They have those configurations and styles there, if you miss this step to select the one you want you will make a mistake See my photo #2 part number on box #3 that I selected and got the right one.2. Mirror cover and base plate lock up too tight.... you are right but it is just the plastic ( the lighter color plastic ) on the cover that is a little plum- use the tip of a knife to shave a little out and it open and close finely. See picture#13. The unit works very well, you have to have map, use the compass N to find the N on earth, place the map to align N to match with the Compass N then ready for you to select your target area on paper map and then use your compass plate as a rule to draw a line from where you are as point A to your target as point B by this step you should know the direction of travel and the degree you will go then turn the ring to place that degree to line up with the red arrow on the base plate to the center line of the mirror that you will need to guide you while maintain MN arrow in the red N box that point to N. Turn your self to get that red arrow in box as said then travel the direction the painted arrow on the plate to to the degree on the ring and the mirror then walk by maintaining the MN in the box if you side step your direction the MN arrow will be out of the red N box turn yourself to put that MN arrow back in red N box to correct your direction and move on that is compass work... Remember that there will not have an arrow guiding you to your target...
    M
    Michael
    Good Quality, Useful Compass
    I was a little worried after seeing some of the reviews here, but the SUUNTO MC-2G USGS (360 degrees and global needle variant) I received is very nice. The numbers and directions are printed clearly and precisely, and there are no manufacturing defects nor structural integrity issues. A very well made compass.I only have a couple minor nitpicks. The first is that setting the magnetic declination is a little challenging to get precise, but once you have it where it needs to be it's reliably accurate - double check it by lining up the "shed"/"doghouse" directly ahead and view from the mirror line. For me the local magnetic declination is about 3 degrees west, which is one and a half marks counterclockwise from true north. The second nitpick is that the hands of the compass can get held up with the pitch angle plumb line arm. This seems to only be an issue when using the pitch angle function of the compass, but not when holding it flat and using it as a compass. For that it spins freely and accurately.I attached my own lanyard with pace counting beads - to stow the compass in a breast pocket or chest plate carrier admin pouch and let the lanyard hang out from there to use.So, based on the one I received at least, I can highly recommend this compass. Thanks.
    A
    Anonymous
    Great
    Great Compass
    K
    Kathryn Muavesi
    Fast shipment
    Fast shipment. Great Compass.
    L
    LUIS E. PEREZ-VENEGAS, Ed.D
    The hard copy documentation that comes with the compass is printed using a very small font that is
    The hard copy documentation that comes with the compass is printed using a very small font that is difficult to read. I located a PDF version in English on a Suunto site; however, this was missing the MEASURE STEEPNESS ON MAP instruction found on the multi-languge hard copy User Guide. In the end, I had to create my own documentation. I scanned the missing instruction and the related figure from the hard copy and integrated these with my own revised PDF version.
    G
    Guilherme DE AZEVEDO
    Best mirror compass
    Best mirror compass ever!!!!
    T
    Tobi James
    Compact, sturdy and accurate.
    A
    Anonymous
    Sturdy and accurate
    A quality compass with all of the tools I'll need to stay on the straight and narrow.
    Y
    Yonatan Libbie
    Built for professionals, and novice friendly.
    This compass has always exceeded my expectations. I'm experienced with navigation (as a pilot) and I'm teaching my partner the essentials. She finds it well designed and easy to understand. Easier than a lensatic and no need to carry extras (like a Romer device). Ordered direct from SUUNTO and saved on the compass and shipping. Well done!
    A
    Anonymous
    Great
    Great
    P
    Pablo Martinez Marcial
    It's an awesome EDC gadget
    It's an awesome EDC gadget, the problem it's way to expensive!! 🤨😯, but it's still considered to have👋👍
    C
    Charles Zinsmeyer
    Very nice compass!
    Very nice compass. Will serve my backcountry needs for many years.
    R
    Reilly DILLON
    Outstanding
    Outstanding compass!
    A
    ANDREW WISLAND
    High quality.
    High quality.
    A
    Anonymous
    Excellent
    Excellent
    A
    Anonymous
    Excellent compass
    This is an excellent compass with all the advanced features you would expect. I am very impressed with the product but wish the directions were more detailed. It would have been a nice touch if the local declination for my area was included.
    r
    robert Greene
    This is one of the best compasses for Navigating around the Mountains of the West in US
    This is one of the best compasses for Navigating around the Mountains of the West in US. The newest one has a very defined pointer for adjusting delineation unlike the one that I got 20 years + ago
    R
    Robert Harrah
    Great product! Very well crafted and packaged
    Great product! Very well crafted and packaged.
    V
    Vance Loertscher
    This is the compass I carry when in the field
    I have several compasses, including lensatics, Conat-4, and several MC-2s. The MC-2 G USGS is the one I carry and use the most. It is reliable, rugged enough, and has the features I need the most. Although I wish the grid scale included a full northern portion I can use protractors for positioning. This is an excellent compass and I recommend it.
    A
    Anonymous
    Missing a Rear Site?
    I really enjoyed using a mirror type orienteering compass for the first time at an organized event. The difference between this and a base plate design was notable. I did fumble with the lanyard where it was too short to use around my neck and hold out in front of me for a sighting. But those comments don’t speak to this particular model. The one design hang-up was the “rear site”, if you will, that I used when sighting a bearing. The red lanyard slides left to right in its slot and either causes me to misalign or vary my sighting. A hard proper rear site would be nice. Otherwise the compass was good quality and otherwise smartly made.
    W
    W Darrin Dawkins
    Very Satisfied with the mc 2 Very Dissatisfied with the Smaller Compass's that I purchased
    Very Dissatisfied with the Smaller Compass's that I purchased. I bought 2 of the Smaller Ones and they areVery Cheaply Made. I wish I had just gotten another mc2.
    A
    Anonymous
    Quarter degree accuracy out of the box
    I sighted a known feature about 6.5 km from my house and was accurate to within a quarter of a degree. Other compasses that I own don’t match that accuracy.
    A
    Anonymous
    Readable
    Readable, no need for wait for the needle settle.
    A
    Anonymous
    It’s a nice
    It’s a nice compas
    H
    Hector Bustamante
    Best Compass I have ever purchased by
    Best Compass I have ever purchased by far!
    E
    Eric Fishell
    This is a straightforward compass
    This is a straightforward compass. Simple to use and understand I can apply it to my navigational needs. I was in the military and used the standard
    lenzatic compass which I was very familiar with. The MC-2 is so much easier to use. I've had many suunto compasses in the past. And I always come back to the brand because I know it will not let me down it never has.
    Recommended products
