Suunto 9 Peak Pro
Titanium Sand
Pro version of the small and sleek multisport watch for smaller wrists.
Choose your Color
        Durability and looks,
combined
      Suunto 9 Peak Pro is a powerful multisport watch with extended battery life and military-grade durability.
The ultra thin and timeless design makes it beautiful on the outside, too.
  Enjoy the smooth interface
    In sports, every second counts. Thanks to the powerful chipset, Suunto 9 Peak Pro reacts faster to your touch than ever before.
We also completely redesigned the user interface, making it even more intuitive to use and easier to read.
Best-in-class battery life and improved GPS
    Even on longer adventures, Suunto 9 Peak Pro is a reliable companion. It features the best battery life of similar-sized sports watches: up to 40 hours in the best GPS mode.
The superior GPS allows you to see your location, pace and distance with greater accuracy, even in challenging environments.
Battery life
With Suunto 9 Peak Pro, you can push your limits without worrying about running out of power. Performance mode is activated by default at the start of exercise. If you need to keep going longer, you can change the mode in the watch settings.
    Training, continuous tracking
Up to 40 hours
Performance mode, best GPS accuracy (single-band)
Up to 300 hours
Up to 21 days
Daily heart rate on, display wakes on wrist-raise
Up to 30 days
Extremely tough. Extremely elegant.
    The robustness of the Suunto 9 Peak Pro sports watch was tested according to US military standards. Waterproof up to 100 meters, it is built from the highest quality materials, such as sapphire glass, stainless steel and titanium in selected versions.
Toughness can still look elegant. Together with its predecessors, the Suunto 9 Peak Pro is the thinnest GPS multisport watch on the market.
Made for adventures, from trails to underwater
    What’s your exercise of choice? With presets for more than 95 sport modes, you’re good to go whether you’re at the gym or climbing a mountain. Receive personalized feedback on your training load, progress and recovery, calculated based on heart rate variability (HRV). For more information, follow your efforts in Training Zone on Suunto App or coaching tools such as TrainingPeaks.
With a dedicated snorkeling mode, Suunto 9 Peak Pro is ready to accompany you on your underwater adventures.
Enhance your experience with Suunto app and SuuntoPlus™
    Suunto app helps you plan, analyse and share your routes, workouts and activity data. You can connect to over 200 partner apps, such as Strava, komoot and TrainingPeaks.
Within the app, you'll find the SuuntoPlus™ Store, where you can customize your watch even further with new features and connected devices. Make it yours!
Specifications
                    Measurements43 x 43 x 10.8 mm / 1.69 x 1.69 x 0.43 "
                    Weight55 g / 1.94 oz
                    Bezel material:Titanium Grade 5
                    Glass material:Sapphire crystal
                    Case material:Glass fibre reinforced polyamide
                    Strap material:Silicone
                    What's in the box?Suunto 9 Peak Pro Titanium Sand, charging cable, printed user documentation
                    Country of manufactureCN
Technical specifications
                        Strap width:22 mm
                        Wrist sizes:125-175 mm or 125-200 mm depending on the model (accessory straps -215 mm)
                        Integrated wrist heart rate✔
                        Customizable watch faces✔
                        Touch screen lock✔
                        Touch display✔
                        Color display✔
                        Vibration alert✔
                        Automatic daylight saving time✔
                        Water resistance100 m
                        Battery typerechargeable lithium-ion
                        Firmware upgradable✔
                        Time, date✔
                        Alarm clock✔
                        Dual time✔
                        Automatic timekeeping✔
                        Countdown timer✔
                        Stopwatch timer✔
                        LanguagesEN, CS, DA, DE, EL, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, TR, HE, ZH*, TH*, ZHTW* Chinese language is only available in the China edition watches.
                        BacklightLED
                        Configurable backlightautomatic brightness
                        Button lockduring exercise
                        Display size1,2"
                        Display typematrix
                        Display resolution240 x 240
                        Battery indicatorpercentage / icon
                        Metric and imperial units✔
                        Blood oxygen✔
                        Automatic firmware updates over the air✔
                        Always-on display✔
PHYSICAL SPECIFICATIONS
                        Operating temperature-20° C to +55° C / -5° F to +130° F
                        Storage temperature-20° C to +55° C / -5° F to +130° F
                        Recommended charging temperature0° C to +35° C / +32° F to +95° F
BATTERY LIFE
                        Intelligent charge reminders✔
                        Daily use: Smartwatch modeup to 21 days
                        Daily use: Standby time mode onlyup to 30 days
                        Training: All-Systems GNSS mode + Single-Bandup to 40h
                        Training: All battery modes battery promises40h / 70h / 300h
                        Training: Power saving GNSS modesup to 300h
COMPASS
                        Digital compass✔
                        Tilt compensation✔
                        Declination correction✔
                        Direction scaledegrees / mils
                        Needlenorth indicator
                        Compass accuracy5°
                        Compass resolution1°
CONNECTIVITY
                        Connectivity (between devices)Bluetooth
                        Compatible with Suunto app✔
                        Media controls on watch✔
                        Send predefined replies to incoming messages from watchAndroid only
                        Compatible with online sports communities✔
                        Phone notifications on the watch✔
                        Watch software updates from cloud✔
                        Automatic over the air software updates✔
                        Smartphone compatibilityMost common models supported
MUSIC
                        Control your music with watch✔
24/7
ACTIVITY TRACKING
                        Step counter✔
                        Calories burned✔
                        Activity targets✔
                        Activity history✔
                        Calorie burn rate and heart rate during daily activities✔
                        Daily minimum heart rate tracking✔
SLEEP TRACKING
                        Sleep duration✔
                        Bed times✔
                        Time awake✔
                        Deep sleep✔
                        Sleep quality✔
                        HRV from sleep✔
                        Average and minimum heart rate during sleep✔
                        Light sleep✔
STRESS AND RECOVERY
                        Stress and recovery status✔
                        Daily resource level✔
                        HRV measurement✔
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
                        Satellite systemsGPS, GLONASS, GALILEO, QZSS, BEIDOU
                        Intelligent battery modesPerformance, Endurance, Tour, Custom
                        GPS recording rateBest, OK, Low
                        Waypoint and visual route navigation✔
                        Zoom levels in navigation✔
                        Auto zoom based on route shape✔
                        Breadcrumb trail in real time✔
                        Route planning with altitude profile✔
                        Outdoor terrain and satellite maps✔
                        Global heatmaps for 20 sports✔
                        Route planning with heatmaps✔
                        Personal route library synced to watch✔
                        Snap to route✔
                        Point of Interest (POI) navigation✔
                        ETA (estimated time of arrival)✔
                        GPS track analysis✔
                        Track logging, viewing and sharing✔
                        Simultaneous satellite systems4
                        Max connected satellites32
                        Outdoor maps by satellite, terrain and topography in web by Mapbox, Google Maps & Android✔
                        Bearing navigation✔
                        GNSS frequency supportL1
                        ETA (estimated time of arrival), remaining distance✔
ALTIMETER
                        Barometric altitude✔
                        GPS altitude✔
                        Combined GPS and barometric altitude (FusedAlti™)✔
                        Altitude in daily mode✔
                        Altitude acclimation with blood oxygen✔
                        Total ascent/descent✔
                        Vertical speed✔
                        Automatic alti/baro profile✔
                        Log recording rate1 s
                        Resolution1 m
                        Range-500 - 9999 m
WEATHER
                        Sunrise/sunset times✔
                        Storm alarm✔
                        Sea level pressure✔
                        Temperature✔
                        Temperature display range-20° C to +55° C / -5° F to +130° F
                        Temperature resolution1° C / 1.5° F
                        Pressure resolution1 hPa
                        Altitude graph shown in exercise summary✔
TRAINING FUNCTIONS
INTERVAL TRAINING
                        Setup intervals✔
                        Interval guidance during training✔
                        Structured intervals✔
HEART RATE
                        Heart rate measured from wrist✔
                        Heart rate belt compatibilityBluetooth Smart belts
                        RR intervalwith Suunto Smart Heart Rate Belt & Suunto Smart Sensor
                        Heart rate in beats per minute✔
                        Records heart rate in swimming✔
                        Heart rate graph in real time✔
                        Real-time average heart rate✔
                        Calories✔
                        Peak Training Effect✔
                        Recovery time✔
                        Personal heart rate zones✔
                        Fitness level (VO2max)✔
SPEED AND DISTANCE
                        Cadence based speed and distance✔
                        GPS speed and distance✔
                        Chrono✔
                        Foot POD supportBluetooth Smart
                        Autolaps✔
                        Manual laps✔
                        Analysis of pace, speed graphs and tracks on the map✔
TRAINING RECOVERY
                        Training based recovery time✔
                        Feeling stored after training to watch✔
TRAINING LOAD
                        Logbook with exercise details✔
                        Exercise summary with lap details✔
                        Training load with totals by sport✔
                        Training logbook for long term overviews✔
                        Log summary on the watch with lap details✔
SHARE AND RELIVE
                        Exercise sharing to social media✔
                        Exercise rating and commenting✔
                        Follow other members and get feedback via activity stream✔
ADAPTIVE TRAINING GUIDANCE
                        Intensity and duration based real-time guidance during workout✔
SPORT EXPERTISE
SWIMMING
                        Pool swim pace and distance✔
                        Openwater swim distance✔
                        Swimming time by pool length, lap, total✔
                        Swimming stroke rate, count and type✔
                        Stroke efficiency (SWOLF)✔
                        Automatic intervals✔
                        Interval lap table✔
RUNNING
                        Running pace✔
                        Suunto FusedSpeed™✔
                        Snap to route✔
                        Running powerfrom wrist or with Stryd sensor
                        SuuntoPlus™ Ghost runner✔
                        Foot POD calibrationautomatic
                        Lap table in watch and Suunto app✔
                        Average, max, lap pace in real time✔
                        Interval guidance with running pace/heart rate/distance✔
CYCLING
                        Cycling speed✔
                        Average speed in real time✔
                        Bike POD with speed/cadence supportBluetooth Smart
                        Bike power meter supportBluetooth Smart
                        Bike Power (W), average and maximum (with power sensor)Bluetooth Smart
                        Bike Lap and Lap Maximum Power (with power sensor)✔
                        Real-time lap table with avg HR, avg power and avg speed✔
                        Interval guidance with power/speed/heart rate✔
MULTISPORTS
                        Change sport mode during exercise✔
                        Preconfigured multisport modes✔
                        Post-analysis of multisport exercise by sport✔
                        Multisport exercise summary on watch✔
SPORT MODES
                        Customizable sport modes and displays✔
                        Graphical displays in sport modes✔
                        Pre-installed sport modes on watch> 95
                        SuuntoPlus™Yes, check the details from here
DIVING FUNCTIONS
FREEDIVING
                        Depth meter for snorkeling10 m
