Suunto Ambit3 Vertical Black
The multisport GPS watch for planning and tracking your elevation gain
$0
The vertical experience for multisport
Some call it obsession, we call it dedication. The Suunto Ambit3 Vertical is more than just a multisport GPS watch. Follow the altitude profile of your route while working your way up mountains. Keep track of your total vertical gain from your yearly total to day-by-day ascents.
PRODUCT HIGHLIGHTS
- The GPS watch with advanced training and recovery functions
- Plan and track your elevation gain with ease
- Relive and share your experience
Specifications
Measurements50 x 50 x 15 mm / 1.97 x 1.97 x 0.59 "
Weight74 g / 2.61 oz
Bezel material:Steel
Glass material:Mineral crystal
Case material:Polyamide
Strap material:Silicone
What's in the box?Suunto Ambit3 Vertical Black, USB cable, quick guide, warranty leaflet
Country of manufactureFI
MULTISPORT
- 15h battery with 5 sec-GPS accuracy (1 min-accuracy: 100h)
- Speed, pace, distance
- Altitude (FusedAlti™)
- Route navigation and track back
- Compass
- Heart rate while swimming**
- Bike power support (Bluetooth Smart)
- Multiple sports in one log
- Activity based recovery time
- Quick recovery and sleep recovery tests (Firstbeat)**
- Movescount training programs on the watch
- Extended feature set through Suunto Apps
- Languages: EN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
PLANNING AND TRACKING ELEVATION GAIN
- Route planner with topographic map***
- Discover new routes with heatmaps on Suunto Movescount
- Altitude profile and total ascent visualization***
- Route altitude profile on watch
- Vibration alerts on watch
- Real-time hill incline percentage****
- Vertical gain totals per day, week, month and year
- Compatible with Stryd Running Powermeter
- Compatible with Bluetooth Smart power sensors
RELIVE AND SHARE
- Mobile notifications*
- Relive and share your experience in social media
*with Suunto app
**with Suunto Smart Sensor
***in Suunto's Movescount.com
****in Suunto Apps
Note! The Ambit3 watches are Bluetooth Smart compatible, not compatible with ANT+™ (e.g. Suunto ANT PODs, Suunto Dual or Suunto ANT belt)
Technical specifications
Water resistance100 m
Battery typerechargeable lithium-ion
Firmware upgradable✔
Time, date✔
Alarm clock1 daily alarm
Dual time✔
Automatic timekeeping✔
Automatic daylight saving time✔
Countdown timer✔
Stopwatch timer✔
Vibration alert✔
LanguagesEN, CS, DA, DE, ES, FI, FR, IT, JA, KO, NL, NO, PL, PT, RU, SV, ZH
BacklightLED
Configurable backlightbrightness / mode
Button lockcustomizable
Invert display✔
Display typematrix
Display resolution128 x 128
Battery indicatorpercentage / icon
Metric and imperial units✔
Autoscrolling of exercise displays✔
Memory left indicator✔
BATTERY LIFE
In time mode14 days
Training mode with GPS10, 15, 100 h For more information www.suunto.com/software-updates
CONNECTIVITY
Smartphone compatibilityiPhone, Android
Data transferWireless / USB cable
Watch customizationUSB cable
Connectivity (between devices)Bluetooth Smart
Phone notifications on the watchwith Suunto App
Compatible with online sports communitiesStrava, TrainingPeaks, MapMyFitness and others (available in Suunto app)
SUUNTO APPS
Compatible with Suunto Apps✔
Max. nr. of apps per sport mode5
Logging of app specific metrics✔
Most recommended apps by activity✔
Chrono, GPS, HR, weather and altitude data✔
Running, cycling, swimming data✔
Rich math functions, if/then-logic, sound, backlight, etc.✔
Create own metrics with advanced formulas✔
COMPASS
Digital compass✔
Tilt compensationfull
Declination correction✔
Direction scaledegrees / mils
Needlenorth indicator
Compass accuracy5°
Compass resolution1°
Bearing lock with direction indicator✔
PHYSICAL SPECIFICATIONS
Operating temperature-20° C to +60° C / -5° F to +140° F
Storage temperature-30° C to +60° C / -22° F to +140° F
Recommended charging temperature0° C to +35° C / +32° F to +95° F
OUTDOOR FUNCTIONS
GPS TRACKING & NAVIGATION
Satellite systemsGPS, GLONASS* *The support for GLONASS, the Russian satellite navigation system, will be available later via a software update.
GPS recording rateBest, Good, OK
Coordinate systemsWGS84 Hd.d° WGS84 Hd°m' s.s'' WGS84 Hd°m.m UTM MGRS British (BNG) Finnish (ETRS-TM35FIN) Finnish (KKJ) Irish (IG) Swedish (RT90) Swiss (CH1903) UTM NAD27 - Alaska UTM NAD27 - Conus UTM NAD83 New Zealand (NZTM2000)
Waypoint and visual route navigation✔
Max. nr. of Points of Interest (POIs)250
Find back✔
Track logging, viewing and sharing✔
Route points per route / POIs in watch1000 / 250
GPS track analysis✔
Route planning with altitude profile✔
Route altitude profile navigation in real-time✔
Route planningin Suunto Movescount.com
Track backyes
ALTIMETER
Barometric altitude✔
GPS altitude✔
Combined GPS and barometric altitude (FusedAlti™)✔
Altitude graph✔
Total ascent/descentair pressure based
Vertical speedair pressure based
Automatic alti/baro profile✔
Altitude differenceyes** ** available as Suunto Apps
Log recording rate1, 10 s
Resolution1 m
Range-500 - 9999 m
Total ascent summaries on watch✔
WEATHER
Temperature✔
Temperature display range✔
Tide informationyes** ** available as Suunto Apps
Temperature resolution1°
TRAINING FUNCTIONS
SPEED AND DISTANCE
GPS speed and distanceIntegrated
Foot POD supportBluetooth Smart
Bike POD supportBluetooth Smart
Distance based autolaps✔
Chrono✔
Laps> 1000
Autopause✔
HEART RATE
RR interval✔
Heart rate in beats per minute✔
Heart rate in % of max hr✔
Records heart rate in swimmingyes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Real-time average and max heart rate✔
Heart rate limits✔
Heart rate graph in real time✔
Calories✔
Peak Training Effect✔
Recovery time✔
Real time EPOCyes** ** available as Suunto Apps
Speed and heart rate-based guidance during exercise✔
TRAINING RECOVERY
Training based recovery time✔
Sleep recovery test (Firstbeat™) For availability information check www.suunto.com/software-updates✔
Quick recovery test (Firstbeat™)✔
TRAINING LOAD
Log summary on the watch with lap details✔
Training analysisin Suunto App
Training logbook with story and image supportin Suunto App
SPORT EXPERTISE
SPORT MODES
Customizable sport modes and displays10 modes / 8 displays per mode
MULTISPORTS
Change sport mode during exercise✔
Preconfigured multisport modes✔
Post-analysis of multisport exercise by sport✔
RUNNING
Running pace✔
Suunto FusedSpeed™✔
Running Performance (Firstbeat™) For availability information check www.suunto.com/software-updates✔
Average pace in real time✔
Running cadencewatch or Foot POD
Foot POD calibrationmanual or GPS
Average stride lengthyes** ** available as Suunto Apps
Marathon End-time Estimatoryes** ** available as Suunto Apps
Lap comparisons by kilometer/mile✔
Running powerwith Stryd sensor
CYCLING
Cycling speed✔
Average speed in real time✔
Multiple Bike POD support✔
Cadence POD SupportBluetooth Smart
Hill incline in real timeyes, available as Suunto Apps
Bike Power (W), average and maximum (with power sensor)Bluetooth Smart
Bike Power 3s, 10s, 30s (with power sensor)✔
Bike Lap and Lap Maximum Power (with power sensor)✔
Normalized Power (Suunto Apps / TM by Training Peaks)✔
Aerodynamic drag in real time (with power sensor)✔
SWIMMING
Pool swim pace and distance✔
Openwater swim pace and distance✔
Records heart rate in swimmingYes, with Suunto Smart Heart Rate Belt & Suunto Smart Sensor
Swimming time by pool length, lap, total✔
Swimming stroke rate, count and type✔
Swim styles detection with personal style teaching✔
Stroke efficiency (SWOLF)✔
Automatic intervals✔
